View Poll Results: Hello
Gts
2
100.00%
Transmission
0
0%
Adaptation
0
0%
Gearbox
0
0%
Voters: 2. You may not vote on this poll
Mercede gts adaptation 287c00
mercedes sls
Hello
my problem with my car from 6 month
first my gearbox leaking so i rebuild the gearbox
then just one problem code fault by xentry287C00 Adaptation was not completed successfully.
so i try to do the adaptation is stop in 42% and stop
is said check the oil drive the car …….
i check the car 100 times
and i test the gear value by xentry every thing fine also i did flashing valve and work test and everything and i can drive the car but in limp mode so i drive until 3th and u can chaneg the gear by manual i used the car so i need to find anything
alots of people around the word said come temeview. Mybe just for temview i pay 4000 dollar and no one can help
I send the car to the dealership 7 times and they said just change the gearbox
i change gearbox from out said from friend car and also the adaptation is not complete
so no one can help from 6 month
so i told to the dealership change the tcu the said ok but if the problem not from the tcu we are not responsible i dont know what i do more
i know my gearbox no any fault i drive the car alot no leaking no elc or solonied or valve fault any help plz the car fron 6 month like this
also sry about my English is not good enough
