Can I run CCB front with iron rears ? Insane rotor wear
I really think you need to diagnose the issue immediately before you have a potentially serious front brake failure on track, at speed.
Take care out there.
Girodisc has been helping me a ton to get to the bottom of this. Mike has spent hours with me on the phone. Robyn as well. Great group of guys that clearly have engineer backgrounds.
made some changes. Same front GP30 pads. Swapped the rear GP20 pads with a new GP25 compound. Trying to balance the system out better. Removed titanium backing plates. Da front rotors and new pads. Results so far :
Greatly improved braking and feel. Braking deeper and much more confidently. 👍. Certainly a factor with my improved times. Funny how that works. Feeling more confident you won’t smash into a wall at 120 plus mph. 🤔
rears finally showing the typical heat cracking. Calipers got hot and discolored some. Finally sharing the load.
didn’t notice much of any smoking coming into lots.
ran 47 laps in 7 sessions vs last outing was 46 laps in 5 sessions. Full laps not counting outlap.
mine big difference however was my trans was overheating. Causing me to do cool down laps after 10 min. Giving the brakes a decent break from the heat. Without the same sustained heat as before it’s hard to n is where it’s at completely.
I did look at the rotors and pads. Zero heat cracking on rotors so far. Pads looked very thick from what I could see. I’ll pull the wheels and measure shortly and report back. Looks promising.
someone else I know has a tuned ,slicked , suspension GTS running 1:35s. He’s using Girodisc and Endless pads. Says he gets about three days on pads and maybe 6 or more on rotors. He wasn’t sure on rotors.
Also, you mentioned switching back to the OEM setup when we were hanging out. I'm still leery about using the CCMs because of the rapid degradation at elevated temperatures...such as the ones you'll probably encounter at Laguna Seca on a warm day. I'll send you a photo of my front CCMs on my 991 Turbo S at the corkscrew the one time I used them...haha
I feel much more optimistic now. Car felt so good yesterday. Just wish I could have gotten full sessions. Obviously it’s when things get the hottest they wear the quickest. I want to go full sessions.
