Footwell speaker maximum mounting depth
Old Sep 17, 2023 | 01:43 PM
TModelle's Avatar
C190
Does anyone know the maximum mounting depth of the footwell speaker?
Old Sep 17, 2023 | 04:14 PM
Stenzel-Germany's Avatar
AMG GTR
Hi,
I can't give you a measurement now. I also replaced these speakers. In order to mount a good speaker, you definitely need a spacer ring. You need more depth and also for fastening. The series speakers have an unusual 4 x 165mm bolt circle.. Stud bolts are also mounted on the car side. I recommend 25mm, then you can complain without changing anything on the car.
Look here:
Sound Upgrade with 10" Subwoofer for GTR - MBWorld.org Forums
Kind regards.
Stenzel
Old Sep 17, 2023 | 11:06 PM
TModelle's Avatar
C190
Originally Posted by Stenzel-Germany
Hi,
Look here:
Kind regards.
Stenzel
4 x 165 is indeed a little odd. Usually we see 165mm as the outer diameter and a bolt circle of 4 x 156mm on most European speakers.
I have a set of speakers in my storeroom that I am hoping to use, since I already have them. It has a depth of 51mm and a large magnet diameter of 110mm.
I was hoping to find out if those would fit before taking everything out!
