AMG GT 2017 - Spoiler Cavity Leak into boot
2017 AMG GT
https://mbparts.mbusa.com/v-2017-mer...and-components
My issue is that I can't tell which part I need from the diagram.
My trunk is leaking from the spoiler drain hole. The nipple that connects from the underside of the trunk to the cavity on the underside of the spoiler is damaged causing the nipple to not apply enough pressure on the grommet on the underside of the boot lid to cause a watertight seal.
From the outside, the part looks like a hollow drain plug that is clipped into place. From the other side, it looks like a right-angle hose connector. From the link, it looks like the part might be part 3 or 10 but i need confirmation.
Anyone that can provide some advice, it would be very well appreciated!
Are you local to the naperville dealer? If so see if they have it in stock and go to parts and look at those parts in person would be your best bet.
GL.
