Red Line Oil 75W90NS GL-5 GEAR OIL for AMG GT transaxles
"Thank you for contacting Red Line Oil, in the gear portion of your transaxle the 75W90NS would be recommended, a suitable replacement for the 236.26 fluid. I will adjust the mapping, thanks for bringing it to my attention.
Regards,
Dave Granquist"
Here is the listing of OEM compatibility from their site:
RED LINE 75W90NS HIGH-PERFORMANCE GEAR OIL is a fully-synthetic formula with ester base stocks, designed for use in manual transmissions and transaxles that require GL-5 lubricants. This non-slip formula is formulated for shear stability, less gear noise and consistent viscosity. Extreme pressure (EP) additives allow for use with hypoid gears, but the lack of friction modifiers causes less slipperiness for proper synchronizer operations. Friction modifier can be added or used to customize limited-slip differential operation.
Suitable replacement for:
Alfa Romeo
Agip 75W-90 SX
Agip SXA 75W-90
Dodge/Jeep 4549636
Ferrari 75W90
GM 88862475
GM 88862476
Mobil Mobilube 75W-90 SHC
Mobil Delvac 75W-90
Mobil Mobilube PTX 75W-90
Porsche 000 043 204 19
Porsche 000 043 204 71
Porsche 000 043 210 12
Porsche 000 043 304 71
Porsche 000 043 305 00
Porsche 000 043 305 48
Porsche Mobilube PTX
Porsche N-052-911-CO
Porsche SHC 75W90
Spirax S5 ATE
Shell Spirax EP 90
Shell Transaxle Oil 75W-90
Shell Spirax S5 ATE 75W-90
Shell TF 1055
Subaru SOA635011
T-10/Top Loader/Muncie
The 75W90NS is designed with the proper coefficient of friction for the synchros, you shouldn’t need to add any friction modifier and it’s use could adversely impact shiftability."
So the fluid straight out of the bottle is the recommended fill. Not sure about the AMG GT with the mechanical LSD.
