Screw/bolt in the center of the oil filter cartridge housing?
Hi, does anyone know what that screw/bolt that's in the center of the oil filter cartridge housing is? Just did my 4th oil change and noticed it. Thanks.
Hi,
Diameter 24 mm
Torque 25 Nm (18,5 ft/lbs)
Best regards
Stenzel
Diameter 24 mm
Best regards
Stenzel
Hey Stenzel! I hope you are well.
I'm not talking about the filter cartridge itself, I'm referring to the screw/bolt that is in the very center of the end of the cartridge. It turns. Is it a way to drain some oil if one were to overfill?
