If your power steering column stops working
Old Apr 16, 2024 | 05:05 AM
Katie22's Avatar
18 AMG GTC and 22 F150 Limited. Past owner 16 Maybach, 17 Brabus Smartcar, 06 Ford E150, and 22 G70
Hi all I have a quick fix for one issue I encountered recently. My power steering column stopped working. By using the scanner I saw that the switch on the column was working so i had to go a little deeper. Turns out that the controller is under the drivers seat and as you might imagine since the seat moves a lot the connectors might be loose and sure enough the solution was to disconnect the connector and clean it and reattach it. All worked great after. VERY simple to fix.
The connector I am talking about as best as I can recall is black on going into a box towards the front of the seat.
