Hello all, 2020 gtr here. Great car but dealership is having a tough time to eliminate code p2c3000 and p2c3100 ,misfire and stalling . First trip to dealership and 2 ignition coils and plugs replaced. Light back again after 10 miles .return to dealership and rest of coils replaced and plugs. Still same misfire and engine light.
Back to dealer 3rd time and ecm replaced, same result misfire after 10 miles. Going back Thursday for further service. They mentioned maybe fuel injectors? Good thing it's still under warranty till 2025.
Any ideas would be a great help , I'm sure they will figure it out but with limited services due to cdk outage we'll see.
Car has 4k miles on it, usually never sits more then a week without being driven. Always kept on a slow charger for battery . In shop now with their number one tech. Will post when issue is fixed.
Hello all , dealership put number one tech on it and found issue in a couple hours. He checked all the grounds and found the chassis ground near the oil pan was loose as it only had a little locktite on it from factory. Fixed and back running.
didn't need ignition coils or plugs or ecm which was replaced by previous techs.
check grounds on all cars before getting crazy replacing parts.
