Replacement exhaust tips help
Subscribe
Feb 4, 2026 | 09:14 AM
Is there any way to swap exhaust tips without removing the rear bumper?
Reply 0
Feb 5, 2026 | 09:09 AM
If it is the same on the GTC as the GT then yes. You need to remove the rear paneling and try.
Reply 0
Feb 5, 2026 | 09:19 AM
Quote: If it is the same on the GTC as the GT then yes. You need to remove the rear paneling and try.
I’ve been told the entire rear bumper needs to be removed. I thought there might be a way to unbolt the rear section of the exhaust and pull them out just enough to replace the tips.
Reply 0
Feb 6, 2026 | 08:33 AM
I replaced the tips on my GT without removing anything. There is a youtube video too. Get under it or drive the rear on ramps, remove the rear bottom panel and try.
Reply 0
Feb 7, 2026 | 06:57 PM
Quote: I replaced the tips on my GT without removing anything. There is a youtube video too. Get under it or drive the rear on ramps, remove the rear bottom panel and try.
The rear belly is very different from a GT to a GTC.
Reply 0
Subscribe
Currently Active Users (1)
