A GTR has landed in my garage!
Old May 15, 2026 | 01:40 PM
W205C43PFL's Avatar
Originally Posted by Kevin#34
Okay, I'll do as you say. However, on the Mercedes-branded charger, there's no option to select AGM or Lithium; the manual says it automatically detects the type of battery it's connected to.
OP, do you mind posting an image of the charger, for us curious minds, include the part number if you can : )
Old May 15, 2026 | 01:42 PM
W205C43PFL's Avatar
I checked the driver's side door sill, but I didn't find any reference to the VIN or the production date, possible?
In case the other forum member still need the information, you can find it right below "Made in Germany" > Build > and format is month/year for example 09/17
Old May 15, 2026 | 01:46 PM
MBNRG's Avatar
In the end, I think that to prevent the battery from losing charge when I'm not using the car, it will be enough to charge it at regular intervals (in theory, lithium batteries don't like being constantly charged to 100%) . . .
Please read this post below by our Engineering colleague. These vehicle Li batteries have somewhat different chemical composition, and electrical properties.
Having your trickle charger plugged in for as long as possible when car is Parked will 'condition' the battery to optimal capacitance/function, and more importantly, will extend its life significantly:
https://mbworld.org/forums/coupe-roa...ml#post9237653
@MBNRG I didn't notice the plaque you're talking about, but I'll take a picture and post it here
This is the referenced plaque as seen below, at driver's side door sill, with Month/Date circled in Yellow. Curious what is your Month/Date?
(PS - The number "589" to the left of Month/Date in photo below corresponds to the MB Paint Code for that specific finish, so your corresponding paint code will be helpful to know if/when you need MB touch up paint - recommend the official MB OEM paint pen, instead of the plethora of aftermarket provider products)
Old May 15, 2026 | 01:49 PM
W205C43PFL's Avatar
https://cimg3.ibsrv.net/gimg/www.mbw...7fbaad6c74.jpg
Interesting so the same as AGM battery in terms of preferring high level of charge.
Old May 15, 2026 | 04:47 PM
Kevin#34's Avatar
AMG GTR 2021 (Euro version)
This:
Old May 15, 2026 | 04:52 PM
Kevin#34's Avatar
Very interesting, thanks!
No sticker on my GTR, maybe not applied on EU version?
Old May 15, 2026 | 05:04 PM
  #32
superswiss's Avatar
2019 C63CS
Yeah, the above are US stickers. Not sure why the poster thought those would be on a EU spec vehicle. I don't recall from the top of my head where this information is found on EU spec vehicles.
Old May 15, 2026 | 05:21 PM
  #33
W205C43PFL's Avatar
Ah looks like the typical trickle chargers for MBs over the years nothing special.
As for the sticker and the manufacture date, the best way is probably decode the VIN on a site like lastvin or something and read the date there, if still curious.
Old May 16, 2026 | 01:48 AM
  #34
user33's Avatar
Originally Posted by user33
FWIW, my GTR is always put on the OEM charger when in the garage and it's been sitting for about a week that way, right now. I just went out and checked the battery voltage and it's sitting at 13.2 VDC which is generally considered to be a 70-80% charge for a Li battery, probably closer to the 80% since some electronics would have been activated by unlocking the rear hatch (i.e., so there was some electrical load).
An Update:
When I checked the battery voltage above, I also decided to press/hold the button to initiate a reconditioning (I think it was Stenzel who suggested this should be done intermittently).
Today I rechecked the voltage (still on OEM charger) and found the voltage was at 13.4 VDC under the same conditions (i.e., hatch had been opened so there was some load from electronics). That reading tends to correlate nicely with the previously mentioned information provided by G.P in this posting:
The "moral of the story" seems to be that Mercedes-AMG recognizes that many of these cars will not be daily deivers and will sit for extended periods and they actually do know what they're doing with the OEM (CTEK) maintenance charger provided with the GT models. $;-))
Old May 16, 2026 | 07:04 AM
  #35
W205C43PFL's Avatar
An Update:
Good stuff
Old May 16, 2026 | 10:49 AM
  #36
det000's Avatar
2020 AMG GT R
An Update:
I can add something that might corroborate this. My previous battery only lasted 4 years with occasional charging via trickle charger. I never let the battery go dead, but I did only drive the car sporadically (every 2-4 weeks). Now I keep it on the trickle charger all the time.
Old Yesterday | 05:19 AM
  #37
Kevin#34's Avatar
thanks to all, I will definitely keep the charger connected all the time !
Old Yesterday | 11:41 AM
  #38
Kevin#34's Avatar
My apologies—I had read your comment but then forgot to reply...
Of course, but since I’d just picked up the car, a bit of initial nervousness combined with a lack of familiarity with the vehicle held me back a little, so I never went over 150/155 mp/h...
Originally Posted by Wolfman
Congrats on your new whip!!
I hope you opened it up on the autobahn. Not a lot of places you can go 200mph and not end up in jail
Enjoy and take more exterior/interior pics!
Old Yesterday | 11:47 AM
  #39
Kevin#34's Avatar
It doesn't seem to be working; when I turn off the ignition, the transmission automatically shifts to P (and when I turn it back on, the P light is on).
[/QUOTE=det000;9290399]edit
As for parking without the e-brake on, IIRC, you just need to stop, put gear selector in N, turn off ignition, and pull the (P) handle on the underside of the dash to the left of the steering wheel. I've done it when I'm at the track.[/QUOTE]
Old Yesterday | 12:39 PM
  #40
W205C43PFL's Avatar
Alternatively, turn off the engine and pull the parking brake at the same time.
Old Today | 01:01 AM
  #41
det000's Avatar
2020 AMG GT R
There was a specific sequence. I think it was something like:
1. Stop the car
2. With the foot on brake, put it in neutral
3. Take foot off brake
4. Turn off car (press Start/Stop)
5. Release the parking brake
And I think you have to leave the key fob inside the car too. You can try pushing the car to see if it's in neutral.
Old Today | 08:44 AM
  #42
Kevin#34's Avatar
OK, thanks, I'll give it a go!
Old Today | 11:42 AM
  #43
thebishman's Avatar
‘24 BMW iX M60
Try doing the sequence with the Driver’s door slightly opened first. Iirc that made it easy to do not engage the Parking brake post road course.
Old Today | 01:02 PM
  #44
W205C43PFL's Avatar
Does the pull and hold on the parking brake and turning off engine not work?
I don't know how to explain it but basically you have your foot off the brake, pull and keep on pulling the parking brake before turning off engine, it works on various MB models I am not certain about the AMG GT but should work, worth a shot.
Push hand brake button is engage and pull is disengage right then pull and keep pulling.
Old Today | 04:23 PM
  #45
W205C43PFL's Avatar
Okay let's see if this helps: https://hips.hearstapps.com/hmg-prod...1635274313.jpg
The parking brake switch right below the light switch on the left, foot on the brake (I mentioned off brake in my previous post but I changed my mind and want to say keep foot on brake because the vehicle may or may not roll back due to an incline until it hits the parking pawl and for safety reasons), you use one hand to pull at the switch like you normally do to release the parking brake but instead of releasing after pulling once, keep on pulling and while pulling, press the ignition to turn off the engine, just remember to keep on pulling.
Once engine is off you can release and stop pulling, confirmed parking brake is off everything is good slowly ease off the brake and let the vehicle slowly roll back until the parking pawl completely stops the vehicle.
That similar feeling when you put an old vehicle in park on a hill and didn't engage the hand brake and let go off the brake and the vehicle rocks back then stops as the parking pawl will keep it in place.
What was the reason to park without the parking brake on again? I forgot if it was mentioned in the thread as I recommend keeping it on to prevent for any reason parking pawl gets disengaged and there is a second layer of protection.
Edit: see further post about brakes wet causing clunk.
Old Today | 04:25 PM
  #46
W205C43PFL's Avatar
If the reason to keep the parking brake off was because of the loud clunk or rust after parking with wet brakes, this recommendation by another forum member might help: https://mbworld.org/forums/s-class-w...ml#post9291264
Another option that was also recommended by another forum member was buy those detailing fan blowers that can be used to blow dry the wheels and rotors and/or um... leaf blower?
Old Today | 04:40 PM
  #47
superswiss's Avatar
2019 C63CS
FYI...OP didn't just wanna park it with the parking brake off, they wanted to park it with the transmission staying in neutral. The above suggestion doesn't do that, and as far as I know you can't turn off the engine with the the transmission staying in neutral. It automatically goes to P, nor can you put it in neutral with the engine off. You may be able to put it in neutral with just the ignition on, but I haven't tried that. If I remember correctly, garage space is limited and they wanted to be able to push the car around without starting the engine, but other than putting it on dollies, that's not possible with these cars as far as I know.
Old Today | 05:02 PM
  #48
W205C43PFL's Avatar
Ohhhhh park in neutral so that is what I missed.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
