removing color on leather
2003 e320
It seems that my leather seats were sprayed to cover up fading and now it is coming off and the color underneathe is much lighter. is there anway to remove this sprayed on color as it is coming off only in certain areas and now looks splotchy. Would leatherique take this off?
Location: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
For obvious reasons a product designed tp properly clean leather will not remove the leather dye.
It sounds like the leather requiers a re-dye, its quite a bit of work but worthwhile in terms of how the interior would be improved, the other alternative is to pay a professional to do it, somewhat expensive as its labour intensive (as I know only too well) or there's the do-nothing option of course.
Surface Preparation-
Leatherique Prepping Agent will remove silicone, wax, dirt, oil, mould, toxins, perspiration and residue from the surfaces to enable proper adherence of the applied product (repairing cuts, cracks or leather surface restoration dye) non-toxic, non-flammable and biodegradable, the formulation safely cleans and prepares all leather surfaces. Ensure a dirt and dust free environment, with adequate ventilation, preferably indoors.
Methodology
•Clean leather surfaces with a 6:1 solution of Water / Woolite®
•Scrub surface with synthetic steel wool #0 and a medium drying lacquer thinner (Recochem's Lacquer Thinner (Recochem Inc) this is a flammable product but with an active ingredient of toluene which is slightly less flammable then other lacquer thinners, ensure the use of adequate ventilation
•Wet-sand surfaces with 240 and 400-grit abrasive papers and a 5:1 lubricant solution (distilled water/Woolite®) to remove existing dye.
•Use a soft horse hair brush (Groit's Leather & Interior Brush) and/or a vacuum to remove any abrasive dust
•Wipe all surfaces with a clean, damp100% cotton Microfiber towel
•Put prepping agent into a fine-mist spray bottle or flask
•Liberally spray a 100% cotton terry towel
•Apply to surfaces with a gentle scrubbing motion to remove any silicone, oils or other contaminants
•Rinse the towel frequently with clean warm water
•When complete wipe all surfaces with a clean, dry 100% cotton Microfiber towel
Surfaces are now ready for leather restoration repairs or the application of a leather dye
JonM
Methodology
JonM
