How to clean Pinnacle Wash mitts?
Washing Directions: Use hot (120oF<) water and add 1-2 ounces to a standard size (8 gallon) load, for larger loads or heavily soiled laundry, add 3-6 ounces. As a pre-spotter: dilute 1 part concentrates with 3 parts water, apply to stain and launder as usual.
Do not use fabric softener (most contain silicone that the towel will adsorb and it will weaken the towels static charge and clog the fibres thereby reducing their effectiveness) towel will also treat the fabric softener as if it was dirt by trying to store the tiny particles of the softener in the towel fibres. This will clog up the micro fibres and render the towel ineffective. Add a teaspoon per towel distilled white vinegar in place of a softener, the vinegar doesn't coat the fibres but instead works to eliminate detergent residue. Vinegar (Acetic acid, pH=2) works well in the rinse cycle to make your towels softer. Detergent is an alkaline (pH=12, the opposite of acidic on the pH scale).
When you wash your towels (or anything for that matter) there are small amounts of detergent left behind, when your add Vinegar it balances the pH of the solution and helps removes the excess detergent from the wash. Do not wash micro fibre cloths / towels with other non- micro fibre fabrics, as they will pick up lint from other fabrics.
JonM
JonM
Are these hand wash instructions or machine wash?
