Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
E55 Car storage
Old Sep 8, 2005 | 09:25 AM
2quik's Avatar
E55 Car storage
getting ready for the winter, where can i buy something to put under my tires , for the months i dont drive it, to prevent flat spots. Thanks in advance
Old Sep 8, 2005 | 09:31 AM
deuce zer0's Avatar
E63
From what I understand, just a piece of a carpet works great.
Old Sep 8, 2005 | 10:20 AM
TOGWT's Avatar
From: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
Vehicle Winter Storage-
Vehicle Storage
·Change the oil and filter.
·Replace brake fluid with DOT 3
·Do not drain the fuel tank, as an empty tank will cause condensation and it will start to rust! Top off fuel tank, then pour Stabil into the tank and run it for a few minutes (to get it into the fuel lines) If you don't cycle your fuel through the tank every two months, it starts an oxidation process and will turn into varnish over time, this can clog your fuel lines, One ounce protects three gallons of any type of fuel.
·Top off coolant with a 50/50 water and corrosion inhibitor and fill all fluids
·Spray distributor with WD-40
·Protect the paint, give the vehicle a good washing, dry it thoroughly and then apply an oil rich polish.
·Clean the interior of the car, apply a generous coating of Leatherique Rejuvinator oil to all leather surfaces, and use a box of DampRid moisture absorbing products, also leave a bar of scented soap under the seats (vermin don't like the smell)
·Apply Wurth HHS-2000 clear spray lubricant to seat rails and sunroof guide rails
·Apply a conditioner to `rubber' weather stripping (Zymol Seal)
·Apply leather conditioner to all leather surfaces.
·Close all windows, trunk, and hood, and stuff the exhaust with a cloth to ensure mice do not enter
·Close windows but leave a small gap to ensure rubber seals are not completely flattened, same for doors, close to first `click'
·Over inflate the tyres (50psi) Do not place car jacks as these will unload the suspension and may do harm. Some vehicles should not be stored with the suspensions unloaded (check with manufacturer)
·Store the car in gear; do not apply the emergency brake.
·Remove sparkplugs and inject a little oil down into each of the cylinders.
·Remove the battery, clean and store separately (the myth about storing a battery on concrete is just that, a myth) coat the terminals with Wurth battery and terminal cleaner, do the same thing with the cable terminals, coat battery hold down bolts with WD40.
·Alternatively use a Battery Tender, a fully automatic two-stage lead acid battery charger, lightweight, compact size, trickle charger that assures batteries are maintained after charging. Ideal for all lead-acid, sealed maintenance free and gel cell batteries. After full 14.4 VDC charge is reached, converts to float charger and monitors battery at 13.2 volts. When voltage drops below 12.6 VDC, charger resumes charging back to 14.4 VDC. Two-colour LED indicator, Spark-proof; reverse polarity protected, twelve-foot output cord and quick-connect harness. Comes with a set of quick disconnect clamps and rings
·Cover the car with a good quality cotton car cover. If you are storing the vehicle outside use a UV sunshade on the windshield and rear window, plus a car cover
·Place a plastic sheet under to the vehicle to avoid dampness capillary action and it will also form a moisture barrier.
·Store convertibles with the top up. Convertible tops can actually shrink if they are left in the down position, for an extended period of time.
·Inspect the vehicle from time to time and check to ensure that the DampRid is still operational
JonM
Old Sep 8, 2005 | 11:50 AM
deuce zer0's Avatar
E63
who says you can never have to much information...
j/k, it was interesting to ready.
Old Sep 9, 2005 | 11:19 AM
2quik's Avatar
I ran out of carpets, lol all my extra carpets are all flat, so anyone know where i can buy something used for tire storage? by the way TOGWT nice post.
Old Sep 9, 2005 | 11:55 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Go to a local carpet reminent place - you can pick-up some cheap indoor/outdoor pieces there.
