still having problems with removing wax !!
E-240 2000 , E-240 2001 , CLS350 2006
i still have some residue from my old wax in dots can any one tell me about a specific product you guys try, and don't tell me use dawn coz i don't want to use dish saop on my car !!!!!!
![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
i used spraywax (meguiars) then i left it for 15 minutes , when i came back to wipe it i found that i apply a lot in some places, so as i was trying to remove it i found that there was dots here and there left over , before two days i used dawn but the dots are still there when i try to remove one of them by hand i remove it , do you think calying the car should remove that ? plus i have some birds spots i can see some after i wash it will clay clean these stuff ???
ricky did you use preston wax before ? we don't have meguiars nxt and ofcourse zaino wax over here although nxt will be available next month but i am using preston for now any idea ?
after claying should i polish or no need to. by the way i just got my car one month ago
Dishwashing soap is a little hard on the finish. If claying is too much work, rubbing alcohol will remove anything wax like from your car. Also, bodyshops use Prepsol to remove any wax like stuff off the car before painting. I use that before touchups because I have it but alcohol will work well too. Don't use spray waxes, they are no good.
Spray waxes are fine but as with any thing, some are good and some stink.
Next time you use a spray wax spray, wipe, buff off....don't let it sit.
Clay your car and then continue with your choice in polish or sealer.
Anthony
Anthony
CLS-500, SL-500, BOXSTER-S
I don't know how bad the dots are, but I've found that spray on quick detailer sometimes does the job. Otherwise, I agree you'll probably have to clay the car.
S500/W220/2000
The biggest problem w/ spray wax is that it doesn't last very long, but if you follow the instructions on the bottle, it will not streak or blot. Regarding dawn dishwahing detergent, I would definitely keep it away from a car's paint finish--stick to dishes. (They don't call it dishwashing detergent for nothing.) I know there is a raging debate about whether to use it on car finishes, but on all of the numerous threads I have followed here, on Autopia, DetailersClub, and elsewhere, regarding Dawn, the professionals (except for Sol Zaino) all say "don't do it!."
S500/W220/2000
Originally Posted by revstriker
But no matter what some uninformed people say on an internet forum, there is no ingredient in Dawn dishwashing liquid that will hurt your finish. It will remove wax which exposes your finish to the elements (which is why it's not a good product to use for regular cleaning), but it does nothing to the paint or the clearcoat of the car. If someone says it does, I would like to know specifically what is contained in dawn that will "hurt" the finish.
It is called detergent, as in Dawn dishwashing detergent!
As I've said earlier, using Dawn will not do any damage to your clearcoat or paint finish. However, if you were to wash your car with Dawn all the time, your car would be unprotected from the elements.
One with 4 wheels
i still have some residue from my old wax in dots can any one tell me about a specific product you guys try, and don't tell me use dawn coz i don't want to use dish saop on my car !!!!!! ![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
You can kinda see the spots on the lining bar thingamabob......
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
![](http://i4.photobucket.com/albums/y116/MoiraineAesSedai/BLAH.jpg)
Okay! I give up... You do your Dawn, and I'll do mine.
Dawn Marie
Dawn Marie
![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
Mercedes-Benz
DAWN should not be used regularly as some people say it does break down some components of the clearcoat. I am not sure if there is any scientific data proven on this but I haven't used dawn on my vehicles more than a couple of times...
That said, I am NOT suggesting that anyone switch from a detergent manufactured specifically to wash cars, to one like Dawn for general use. Dawn should be reserved for when you need to strip off old wax build up, probably at the most, once per year.
S500/W220/2000
The harshest chemical component in Dawn is a small amount of Ethyl Alcohol (Ethanol) which should not have a negative affect on a polyurethane clear coat finish. Granted, ethanol is a corrosive (a rather mild one when compared with methyl alcohol {methanol}), and a long term exposure to it could cause some damage to painted surfaces, and even to a clear coat. But the small amount contained in Dawn, and using it to wash your car in a normal way (wash and rinse) should not damage the clear coat. In theory, parking your car outside in the natural light is more damaging to the clear coat than dawn.
