Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
need help with removing pillers
Old Aug 8, 2006 | 12:30 AM
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
The Arizona sun is taking its toll on the interiour of my S320. The glue is failing and the material on the pillers is pulling away. My question is how to remove the piller so I can put new adhesive on. Anyone familur with interiour work?
Thanks Rod
Drive on
Old Aug 13, 2006 | 11:51 PM
Rod Spohn's Avatar
Bbbbump
Old Aug 15, 2006 | 03:19 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Move the seats all the way back and remove the door seals that are on the door seams then use a angle pair of plyers to remove the trim at each clip...
The B Pillar cover is secured with several clips..done several
Old Aug 16, 2006 | 11:15 AM
Rod Spohn's Avatar
Mark, what about the collums on either side of the front window? Do you have to take off the sun visors and that section?
Thanks Rod
Old Aug 16, 2006 | 12:10 PM
For The A Pillars the sun visors MUST be removed then pry the covers off
