Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
Anyone tried applying soap with this?
Old Mar 1, 2007 | 02:50 PM
5IVE's Avatar
2006 CLS500
Is this ok for applying soap from say Zaino or Meguiar's? After applying of course you would rinse with a jet of clean water. Any input is appreciated, Thank you!
Old Mar 1, 2007 | 08:02 PM
Nickc0844's Avatar
2003 E500
Well worth the investment. The foam gun works well to help reduce swirling when used with a 2 bucket, 2 wash mitt method.
Rinse, then spray down with soapy foam, then wash like normal, then rinse!
Old Mar 4, 2007 | 07:56 AM
TOGWT's Avatar
From: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
Mixing liquid soap (preferably one that contains glycerine or oil to provide lubrication) and water, and them adding air will produce foam, which becomes a Sequestant (Sequester [: to hold in solution) which encapsulates the soils (dirt / grit / etc) and enables their removal without intimate contact with the paint surface, minimizing surface marring or scratches. By using a pH balanced ( to help preserve your wax /sealant ) foam wash will help to remove damaging dirt particles from your paint it's also provides a cushion (foam) to enable a towel to glide just above the surface to avoid rubbing any dirt /grit into your paint finish.
