Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
NEW!!! Daily Specials at Detailed Image
Old Aug 4, 2009 | 02:18 PM
  #351
Greg@DI's Avatar
Today's Daily special (August 4, 2009) is Chemical Guys Fine Grade Clay Bar.
Regular Price for 200 g is $21.99. Today's price is $17.18!
Old Aug 5, 2009 | 04:06 PM
  #352
Greg@DI's Avatar
Today's Daily special (August 5, 2009) is Poorboy's World Super Swirl Remover 2 (SSR 2).
Regular Price for 16 oz is $15.99. Today's price is $11.99!
Old Aug 6, 2009 | 02:12 PM
  #353
Greg@DI's Avatar
Today's Daily special (August 6, 2009) is DI Accessories Sheepskin Wash Mitt.
Regular Price is $9.99. Today's price is $7.49!
  • Perfect wash medium to help minimize adding swirls and other imperfections to the paint
  • The natural fibers help pull contamination away from the surface without grinding them in
  • When done using, rinse any contamination using free flowing water than hang dry with leather hoop
  • For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
Old Aug 7, 2009 | 01:51 PM
  #354
Greg@DI's Avatar
Today's Daily special (August 7, 2009) is P21S Finish Restorer.
Regular Price for 75 ml is $9.99. Today's price is $8.27!
  • Clean, restore and polish your wheels and metal trim in one easy step
  • A little goes a long way, work a small amount of product into the metal with light pressure
  • We recommend using a foam applicator pad for application
  • Use a two sided metal polishing towel to remove excess product and to buff to desired finish
Old Aug 8, 2009 | 01:03 PM
  #355
Greg@DI's Avatar
Today's Daily special (August 8, 2009) is Dodo Juice Born to be Mild Shampoo.
Regular Price for 250 ml is $16.99. Today's price is $14.67!
Regular Price for 500 ml is $32.99. Today's price is $27.84!
  • One of the best shampoos we've tested in terms of lubricity and maximizing your coats of protection
  • Highly concentrated formula means only a little bit of product is needed to achieve great results
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
Old Aug 9, 2009 | 11:55 AM
  #356
Greg@DI's Avatar
Today's Daily special (August 9, 2009) is Clear Kote Fine Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $18.74!
  • Remove embedded surface contamination that does not come off during the washing process
  • Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
  • Helps you get the most out of any step you perform after using the clay bar
  • Use with plenty of clay bar lubricant to minimize any micro-marring that may occur
  • We recommend using Clear Kote Quik Shine as a clay bar lubricant and quick detailer
Old Aug 10, 2009 | 03:12 PM
  #357
Greg@DI's Avatar
Today's Daily special (August 10, 2009) is Grit Guard Grit Guard Insert.
  • A must have for any detailer, minimize adding imperfections during the wash phase
  • Simply place the Grit Guard insert into the bottom of a bucket to trap dirt and contamination
  • Gently glide your wash medium over the Grit Guard insert to release contamination
  • Excellent results with the Lake Country Grout Sponge paired with a Grit Guard bucket insert
Old Aug 11, 2009 | 01:48 PM
  #358
Greg@DI's Avatar
Clear Kote Quik Shine (QS).
Regular Price for 16 oz is $9.99. Today's price is $7.49!
Regular Price for 32 oz is $16.99. Today's price is $12.74!
  • An amazing quick detailer that not only enhances the gloss and depth but also cleans the paint
  • Ideal for removing a coating of light dusting on your paint or for boosting gloss after a wash
  • Works great as a clay bar lubricant
  • Use a plush microfiber towel to minimize adding imperfections and to prevent streaking
Old Aug 12, 2009 | 12:44 PM
  #359
Greg@DI's Avatar
Today's Daily special (August 12, 2009) is Optimum (OPT) Hyper Compound.
Regular Price for 32 oz is $19.99. Today's price is $14.99!
  • A great compound that offers long work times and can be used in the sun or shade
  • Most commonly applied with a yellow cutting pad or purple foamed wool pad when using a buffer
  • Popular amongst mobile detailers who may be polishing outside
Old Aug 13, 2009 | 10:22 AM
  #360
Greg@DI's Avatar
Today's Daily special (August 13, 2009) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6.5" is $9.99. Today's price is $7.49!
  • Our most cutting pad option, however, due to the wool strands, not as much heat is generated
  • Works best on high powered buffers, for fast, effective paint correction
  • Commonly used with a heavy cut compound to remove deep imperfections and wet sanding marks
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Old Aug 14, 2009 | 11:18 AM
  #361
Greg@DI's Avatar
Today's Daily special (August 14, 2009) is Chemical Guys Citrus Wash & Gloss.
Regular Price for 16 oz is $7.99. Today's price is $5.99!
Regular Price for 128 oz is $22.99. Today's price is $17.25!
  • One of our best selling shampoos, lots of foam, great lubricity, strong cleaning power
  • Can be used in high concentration to strip off previous coats of protection from a sealant or wax
  • Can be used very diluted to maintain your coats of protection during regular maintenance washes
  • Works great in a foam gun, such as the Gilmour Foamaster II
Old Aug 15, 2009 | 12:09 PM
  #362
Greg@DI's Avatar
Today's Daily special (August 15, 2009) is Gilmour Flexogen 8 ply Hose.
Regular Price for 50 feet is $34.99. Today's price is $26.34!
Old Aug 16, 2009 | 10:55 AM
  #363
Greg@DI's Avatar
Today's Daily special (August 16, 2009) is Dodo Juice Diamond White Hard Wax.
Regular Price for 250 ml is $69.99. Today's price is $54.72!
Regular Price for 30 ml is $13.99. Today's price is $10.55!
  • The Dodo Juice Diamond White hard carnauba wax is designed to work exceptionally well on lighter colored vehicles
  • Extremely easy to apply and remove, especially when applied in thin layers
  • Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
  • Dodo Juice hard waxes offer slightly more durability than the Dodo Juice soft waxes
  • Apply with a foam applicator pad and remove with a plush microfiber towel
Old Aug 17, 2009 | 07:11 PM
  #364
Greg@DI's Avatar
Today's Daily special (August 17, 2009) is Lake Country Black Finishing Pad.
  • A finishing pad, designed to bring the paint to its maximum depth and gloss with a finishing polish
  • Also can be used to apply a paint cleaner, glaze or sealant
  • Menzerna PO85RD is one of the most popular polishes to use with a black finishing pad
Old Aug 18, 2009 | 11:35 AM
  #365
Greg@DI's Avatar
Today's Daily special (August 18, 2009) is Stoner Invisible Glass.
Regular Price for 19 oz is $5.99. Today's price is $4.49!
  • Foam based formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry microfiber towel
  • For optimal results, give a final wipe down with the low nap, glass microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Old Aug 18, 2009 | 01:04 PM
  #366
Jen_Kenne's Avatar
my wife wild, but she loves every minute of it.
This is great stuff. I have it in a spray bottle.
Old Aug 19, 2009 | 07:43 PM
  #367
Greg@DI's Avatar
Today's Daily special (August 19, 2009) is Lake Country Ulti-Mit.
Regular Price is $15.99. Today's price is $11.99!
  • A paint safe foam wash mitt that has two different surfaces to tackle various areas of your vehicle
  • Holds large amounts of suds and water which helps minimize marring the paints finish
  • Use the red cubed side to wash your paint, as it is the softer of the two sides
  • Use the black side to clean stubborn contamination off of lower panels, tires, wheel wells and more
  • Highly recommended to be used with a Grit Guard insert to easily release contamination
  • Will outlast natural fiber mitts due to the durable foam design
Old Aug 20, 2009 | 11:16 AM
  #368
Greg@DI's Avatar
Today's Daily special (August 20, 2009) is Optimum (OPT) Tire Shine.
Regular Price for 17 oz is $11.99. Today's price is $8.99!
Regular Price for 128 oz is $35.99. Today's price is $26.99!
  • Water based tire dressing that applies easily and does not sling onto your paint
  • Can be applied in multiple layers for a glossier look or buffed down to a matte finish
  • We recommend using a Lake Country tire dressing applicator to apply Tire Shine
Old Aug 21, 2009 | 03:58 PM
  #369
Greg@DI's Avatar
Today's Daily special (August 21, 2009) is Clay Magic Medium Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $20.80!
  • Medium grade bars will remove contamination quickly, however it may result in micro-marring
  • Follow up the medium grade clay bar with a finishing polish to remove any micro-marring
  • We recommend using Poorboy's Spray & Wipe as a clay bar lubricant and quick detailer
Old Aug 21, 2009 | 04:47 PM
  #370
Jen_Kenne's Avatar
https://mbworld.org/forums/w211-amg/...r-vendors.html
See #28
Old Aug 22, 2009 | 11:36 AM
  #371
Greg@DI's Avatar
Originally Posted by Jen_Kenne
Thank you for the post I really appreciate the support and sharing it with others!
Greg @ DI
  #372
Greg@DI's Avatar
Today's Daily special (August 22, 2009) is Dodo Juice Sour Power Gloss Enhancing Shampoo.
Regular Price for 250 ml is $13.99. Today's price is $10.49!
  • Perfect maintenance shampoo that enhances gloss and depth
  • Lots of lubricity and slickness to help minimize adding imperfections
  • Concentrated formula means only a little product is needed per wash
  • Best used with a grout sponge or sheepskin wash mitt
Old Aug 23, 2009 | 02:32 PM
  #373
anistufy's Avatar
SL-500
These are looking great but what about its quality?
Old Aug 24, 2009 | 07:24 PM
  #374
Greg@DI's Avatar
Today's Daily special (August 24, 2009) is Chemical Guys M-Seal Pure Sealant.
Regular Price for 16 oz is $19.99. Today's price is $14.99!
  • One of the best bang for the buck, pure sealants for under $20
  • Easy to apply and remove when applied properly, which is as thin as possible
  • M-Seal not only protects your paint, but leaves behind a great shine and sharp reflections
  • Best applied with a foam applicator pad and removed with a microfiber towel
  • When using a buffer, best applied with a blue fine finishing pad
Old Aug 24, 2009 | 07:28 PM
  #375
Greg@DI's Avatar
It's a good question. We scour the world for quality products and we hand select only our favorite products. We don't just pick up a whole line of products, we pick and choose the ones we like best! We also try to provide informative and factual product recommendations. We base them off our personal experiences and information from the mfgs. If you have any specific questions about these products please let me know.
Greg @ DI
