Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
using Klasse AIO?
Old Jun 9, 2008 | 11:43 AM
ghost1001's Avatar
E550
using Klasse AIO?
Ok,
I took your advice and got some real products for my new to me Benz.
Washed and dried it yesterday, then started with the Klasse all in one.
I am applying with a damp micro fiber pad. It seems to be a little streaky; maybe I am not using enough?
You cannot really see this unless you look at an angle and know what you are looking for...almost like the depth of the black is lighter and darker, not uniform.
If anything I would say I did not apply enough product.
Any advice.
Kevin
Old Jun 9, 2008 | 03:39 PM
Greg@DI's Avatar
I know the bottle says to use it with a damp applicator but I use it dry. Both methods should work. You only need very little product per coat, typically less than one ounce. It should look relatively clear during it's application and as it dries. I would buff it on with medium pressure in logical pattern over a small area (no larger than 2ft x 2ft). After about 15 - 20 minutes you should be able to fully remove the excess product with a clean microfiber towel. This should remove any streaking or hazing. I hope this helps.
Greg @ Detailed Image
