Paint chip repair - Langka vs. Dr. Color Chip
...As near as I can tell, the system consists of (solution one) lacquer, and (solution two) a non-acetone, non-lacquer thinner solvent. I'm wondering if it may be some sort of non-acetone nail polish remover (it's a mild smelling, milky pink that stratifies when allowed to sit). I have considered requesting a MSDS just to know for sure. The kit also includes the nalgene glove, some paint applicators, and a microfiber cloth. You will still need a piece of soft cotton (t-shirt material) for applying the second solution.
Basically you dab the lacquer into the damaged area and lightly wipe the excess with your nalgene gloved hand. Wait a minute or two for the lacquer to dry, then wipe the touched up area with the solvent to level it to the cars surface. You then polish the area with a microfiber cloth to remove any lacquer film from the undamaged paint surface.
I found that deep chips were better covered by multiple passes instead of one heavier application.
I imagine lighter and metallic finishes will render less satisfactory results.
The repaired chips on my car are hard to spot, and the $40-60 for the system is still considerably less than a visit to the paint shop.
I have quite a bit of really small chips together in a group, that Langka didn't work as well on. I think Dr. Color Chip is the better solution for that type of "road rash", but haven't tried it yet. Though, I did order the Dr. Color chip to try for those.
Keep us updated on how it goes with the Dr. Color Chip.
