Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
Buffer Daily Specials for 6 days!
Old Aug 8, 2008 | 02:21 PM
Greg@DI's Avatar
Buffer Week from 8/8 - 8/13
For the next 6 day's, we'll be running the Porter Cable 7424, the Flex XC 3401 VRG and Metabo PE 12-175 on sale at our LOWEST PRICES!
The schedule for the Daily Specials is as follows:
8/8/08 - Porter Cable 7424
8/9/08 - Flex XC 3401 VRG
8/10/08 - Metabo PE 12-175
8/11/08 - Porter Cable 7424
8/12/08 - Flex XC 3401 VRG
8/13/08 - Metabo PE 12-175
We all know that the real results from detailing stem from properly prepping your paint, which includes washing & drying, using a clay bar, and most importantly, polishing your paint to remove as many imperfections as possible. Imperfections are essentially dips and valleys in your clear coat that prevent light from passing through to the paint. Common imperfections in the paint are swirls, scratches, holograms, hazing, water spots, sap and bird dropping etchings. All of these can be treated by using a quality buffer along with the proper polish and pad combination. By polishing your clear coat it will be much smoother and again allow the light to pass through to your paint so your paint can reflect back the deepest and wettest reflection possible. In an idealistic world, the perfect detail would be one with 0 paint defects. Using a quality buffer allows you to remove paint defects, making your clear coat as smooth and as even as it can be. Here's an example of what the Flex XC 3401 VRG can do on some neglected paint and the right polish / pad combos.
Comparing the 3 Buffers:
Porter Cable 7424
The Porter Cable 7424 quickly emerged as the goto buffer for auto detailing enthusiasts. It's biggest draw is how safe it is to use. By utilizing a random orbital motion, it is nearly impossible to damage your paint with some common sense. The downside of the PC7424 is that it can take a long time, lots of coats and passes, to correct severely neglected paint. The Porter Cable 7424 is lightweight and easy to use. It has a maximum speed of 6,000 oscillations per minute (OPMs), where as hand applications can only generate several hundred OPMs. Your polishing and detailing results will greatly improve if you start using a buffer. Don't worry if you have never used one before the Porter Cable 7424 is extremely easy and safe to use. This buffer is perfect for people just getting into polishing their vehicles.
Flex XC 3401 VRG
The Flex XC 3401 VRG changed the way serious enthusiasts tackled polishing their vehicles when it was introduced in the US roughly 1 year ago. This machine is a dual action machine, which means it oscillates as well as utilizes what's called forced rotation. This offers more correction abilities in less time when compared to traditional random orbital that just oscillates. This German built machine is very durable and smooth to operate. With a motor twice the size of the Porter Cable (7.5A vs. 3.7A) and 60% more oscillations (9,600 OPMs vs 6,000 OPMs) this buffer can correct twice as many imperfections in half the time. Some other key features of this machine is the variable speed trigger, ergonomic handle, hand positioning and lightweight design. The Flex is the perfect upgrade for the Porter Cable 7424 and is perfect for the serious auto detailing enthusiast.
Metabo PE 12-175
The Metabo PE 12-175 rotary buffer has quickly emerged as a favorite amongst professionals and serious enthusiasts. The Metabo rotary offers a low starting speed of 700 RPMs, which gives the first time rotary users a safe starting speed. Rotary buffers have the highest potential for results, but can be dangerous if you are not careful. If you want to achieve perfection and you have some patience to master this tool you'll absolutely love this buffer!
Don't Forget Pads and Polishes
I always recommend matching the aggressiveness of the polish with the aggressiveness of the pad. Most commonly you use a white polishing pad with light polishes, orange light cutting pad with medium polishes and the yellow cutting pad for heavy polishes. If you're seeing improvement with the current polish / pad combo, then you can jump to a more aggressive pad for faster results. If the results are minimal with a current polish / pad combo, I'll jump to the next level of polish / pad combo.
We recommend following these rules:
Also important to note, change your pad out for a new one after every few panels or at least clean it out for the best results. The more caked up the pad becomes, the harder it is to finish down as clean as the first panel when the pad is fresh. Excess product can lead to difficult product removal, not being able to break down the polish completely, and excessive dusting. It is not uncommon to use 2 - 4+ pads per coat of polish.
Here are our Lake Country Pads in order of Most Aggressive to Least Aggressive:
Here's a list of Menzerna's best polishes in order of (most aggressive) Compound to (least aggressive) Finishing Polish:
Thanks for reading! If anyone has any questions on anything, or needs a hand putting together a package to best fit your needs, please do not hesitate to ask.
Greg @ Detailed Image
