Concours Finish Detailed: Black SL600
Wheels, Wells & Tires
P21s Wheel Gel Cleaner
Meguiars APC +
Jet Seal 109 to seal wheels
Various Brushes and Foam Tip Swabs
Megs Hyperdressing Tire Shine
Exterior Wash
P21S Total Auto Wash Pre-soak
Chemical Guys Citrus Wash & Gloss
Clay
Chemical Guys Blue Clay
ONR used as Clay Lube
Paint Correction
LC Purple Foamed Wool with Menz SIP
LC Orange Pad with Menz SIP
LC White Pad with Menz PO106FF
Trim
Black Wow
303 Aerospace Protectant
Prima Clarity Glass Cleaner
Glass Polishing Cloth
Meguiars NXT All Metal Polish
Interior
Prima Nero
303 Fabric Guard
Prima Nourish Leather Conditioner
LSP
Chemical Guys Jet Seal 109
Chemical Guys 50/50
Equipment
5.5 Hp Rigid Shop Vac
Karcher Electric Pressure Washer
Cam Spray Foam Cannon
Makita 9227c
Porter Cable 7424
LC 6.5" pads & 4" pads
Thought I'd take a photo of most of the products used
Before Photos
Car looks good in the shade from afar......
But in the sun close up you get.....
Foam Tipped Swabs from AutoGeek. Great for calipers, lug nuts, and other small hard to reach areas.
Can't forget behind the wheels...
Before
After
I always like taking the car outside under the sun to take 50/50s because the sun shows the defects best......
Up Close
Can you tell I like 50/50s ???
Closer
Fender 50/50
Before
After
Before
After
50/50
That's some serious $**** right there!
Thanks for taking the time to post and enligten us.
Just wondering - how did you get the P21S gel to spray evenly on the wheels? I've had a whale of a time trying to get it to spray - to thick to atomize - only squirts out in strainght lines..
