Help! Purple Discoloration After Adhesive Removal!
My car is 04 and black.
I was wondering if anyone could help me find a product or way to remove some purple discoloration that ended up when I removed the plastic diffuser of my e55.
The story:
I removed the plastic rear diffuser of my car because it turned from black to light gray because of age. Underneath is supposed to be fresh paint, and when I did, I noticed streaks and lines of purple around where the double sided adhesive tape was used to mount the plastic diffuser. I'm wondering if there is any product to take this out, or if it could be buffered out?
Thanks!
Greg @ Detailed Image
First of all, I would like to thank you a lot for taking your time and typing a response to help me!
I will try claying the car next week when I have a chance to go home (at school now) and I will see if that is what it needs. Could it be that the sun damage affected the plastic or maybe the double-sided tape adhesive and ruined the clear coat?
About your suggestion about using a buffer with those products that you recommended, if I were to ask a detailer about it, would he know? I myself am not an expert in this department at all and don't even own a buffer, lol.
Thanks again!
Eric
Thanks again!
Eric
No problem at all I'm happy to help out. I'm not sure what the problem is with the surface, it sounds kind of obscure. However with detailing I see unique and new situations on a regular basis. I have a lot of guesses on what may have happened but it's tough to know without seeing it and even then I may only be able to give you an educated guess.
It's fine that you don't have a buffer. You can certainly apply the products by hand first if you want. A buffer would be far more ideal but you may get the results you need from a hand application. A detailer or the dealership may be able to help you out. However the work of these places can vary quite a bit and more often than not it seems doing it yourself is safer. With just a little bit of reading you can do this on your own with a buffer or by hand with better results. We have some very safe and easy to use buffers if interested. I've helped numerous first time detailers get some impressive results with our buffers and polishes. If I can help you any further please let me know.
