Removing Deep Water Spots on Windows?
2006 E350
Hi;
I have an 06 W211 (E350) which I bought used last year.
The rear window has really bad water or other spots in it.
I just purchased the Diamondite window kit and used their spray clay product.
Unfortunately it make any difference - the window shines quite nicely, but the spots are still there (and very noticable looking through my rear view).
Any suggestions about how to tackle this?
I also have similar spots on the black metal trim around the car. The paintwork doesn't seem to have any issues that I can see (however, will be doing a deep clean and Klasse treatment in the near future).
Thanks in advance!
Chip
Thanks in advance!
Chip
I've had good success removing water marks from glass with the Glass Science Glass Scrub. It does a great job of removing all kinds of build-ups on glass and giving it a deep cleaning. Get the glass wet and a foam applicator wet and apply a nickel sized drop on the applicator. With medium pressure buff on the Glass Scrub in a circular motion and then thoroughly rinse the area when you are done. Use firm pressure if needed for deeply embedded marks.
Let me know if you have any other questions I can help you with. Good Luck!
Greg @ Detailed Image
2012 C300 4Matic
2005 C55
Have you tried some sort a cleaner/wax combo? Alot of people do not know that you can wax/buff windows as well as paint. That usually works pretty well. If that doesn't get it, you could always try a light clay bar. Last resort try some window cleaner or tar/adhesive remover with a little steel wool. I have been detailing cars for years, and most of these high dollar products I hear folks talking about are a complete waste of money.
