cleaning carbon fiber?
Correct surface imperfections with a finishing polish and soft foam pad (Menzerna PO 85 RD 3.01 SIP with a Blue finishing (very soft 100 PPI) LC CCS foam pad - 1100 RPM)
Providing protection from ultra violet radiation (UVR) is very important to avoid photo synthesis (colour fading) 303™ Aerospace Protectant UVR protection is a sacrificial / renewable component; this is due to the UV protection layer being degraded by exposure to the elements (sun, sand, road or sea salt, and etc) so it is imperative that you renew it and needs to be re-applied on a regular 45 to 60 day basis (dependent upon location climatic condition)
Application- this product should be sprayed onto a cloth and the surface to be protected should be wet, not just damp with the product. Use a clean, dry cloth and agitate to ensure the protected surface is dry (this product does not air-dry) After application allow 60 minutes for product to cure, then using a 100% cotton cloth to lightly buff surface
For Gel Coat finishes - Collinite Fibreglass Boat Cleaner #920 easily removes dirt, film, oxidation, oil, grease, rust and exhaust stains from resin gel coat / fibreglass finishes. This cleaner restores the original colour quickly without hard rubbing or buffing and leaves a chemically clean surface to which waxes can adhere perfectly. Collinite Fibreglass Boat Cleaner Increases long-lasting brilliance and performance of protective wax coatings
An extract from “Automotive Detailing Inside & Out; a Knowledge Base for the Perfectionist” © – by Jon Miller
Greg @ Detailed Image
