9.What can be done about wax build up along the seams and how can I avoid it? Are you sure it's wax and not the glue from the Clear Bra? As it gets warm, some of them will shrink a little and leave residue around the edges. Gently remove with an adhesive remover on a micro fibre towel. Be sure to go over any paint that you get the adhesive remover on with a protective wax; put a vinyl protection on any clear bra you get the adhesive remover on.
10.When waxing around a clear bra, mask off the line just a little over the edge with blue painter's tape. Wax will leave a white line on the seam, use painter’s tape to mask the seams before polishing / waxing and wax the film and uncovered portions separately to keep from wax build-up.
11.When you remove the tape just wipe off the wax on the paint. If you accidentally wax over the seam, use isopropyl alcohol (IPA) and a Q-Tip or a damp micro fibre towel and rub it off.
An extract from one of a series of in-depth detailing articles © TOGWT ™ Ltd Copyright 2002-2008, all rights reserved.
