Air Force Blaster Car Dryer
If you’re using softened water I see nothing wrong with using an electrical leaf blower dry off your car (just be careful not to bump the hard plastic nozzle against the paint) but if you live in an area that has hard water, it seems that you’d only be accelerating the evaporation process and that those harmful and often damaging alkaline minerals that cause ‘water spot’ damage, would be precipitated out as the water evaporates and must therefore be collecting somewhere, in the seams or crevices perhaps?
My other concern is that these high speed electric (I would be wary of gas powered as it may spew oil) leaf blowers typically have an outlet velocity of 250+ mph. Now if grains of sand or other small dirt particle were to get ingested in the inlet, it would exit and strike the paint surface at a very high velocity, the same would be true for any internal fragments or components such as a screw that might come loose from vibration. Just my opinion but I’d prefer not to take this or any other shortcuts either when it comes to drying.
