Hand Car Wash Near Stamford, CT?
http://www.splashcarwashes.com/categ...norwalk-ct.htm
Edit - They have locations closer to you but I can't speak to them as to whether they are hand wash locations.
It uses a marshmallow type cleaning material that cannot trap or hold dirt the way the sponges can at a hand wash. Also have you seen the bucket they clean from? They typically don't get cleaned often enough. When dirt is trapped into these sponges it is like using sand paper on the car's paint.
This car wash uses an abundance of soap and warm water. Apparently no car washes use warm water because it is way to expensive, but they have solar panels to heat the water. They also don't use acid on the rims, which is horrible for the rim's finish not to mention the braking system.
My car has never been cleaner... rims too. They are pretty inexpensive... $21.95 for a works wash and you can come back within three days for a free exterior.
They are in stamford on greenwich avenue. I looked up their website, it is www.greenwichavenuecarwash.com
