MB-Tex
Location: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
Synthetics -MB-Tex, Artico- this is one of the most difficult types to recognise as they often look and feel more like leather, than well leather. This non-organic material has an even, almost repeating pattern and can very closely imitate leather as they imprint a grain pattern into it; the depth of the lines within the grain on vinyl is also consistent, while the same lines on leather will vary. Vinyl usually has single stitching; whereas leather uses double stitching, as leather is thicker than vinyl.
Periodically clean using a 1:10 solution of P21S Total Auto Wash and distilled water to remove dirt build-up thoroughly and effortlessly, these chemicals restore the original texture and resiliency; use to clean all polyurethane covered automotive upholstery; this product is biodegradable and environmentally friendly.
Protection - even though this material is not real leather, it can definitely crack and distort, with Einszett 1z Cockpit Premium safely cleans all clear and coloured automotive plastic interior fittings such as dash, trim, door panels, navigation/audio screens, steering wheel, and pedals. It leaves a long-lasting matt finish with fresh citrus scent. The perfect everyday cleaner for interior plastic surfaces, it’s a mild cleaner to prevent the drying of these porous surfaces, yet it is effective at removing body oils and grime on a regular basis.
UV-B protection is a sacrificial / renewable component; this is due to the UV protection layer being degraded by exposure to the elements so it is imperative that you renew it and needs to be re-applied on a regular basis (dependent upon location climatic condition)
Application - Spray onto a clean micro fibre towel, agitate it well and then allow it to remain in place for 10-15 minutes. Finally using a clean micro fibre towel buff it to ensure it permeates
{Knowledge Management} - Treating experience as a shared asset. If this article was informative and you learned something new, or have any questions feel free to comment. We would love if you shared this article with your friends on Facebook and Twitter or linked to it from your website or blog. Thanks
