New Product - Optimum Opti-Coat 2.0
Former Vendor of MBWorld
2010 S550
No, you're not seeing things!
For those of you that are familiar with the original Opti-Coat, you are well aware that its durability is second to none, but it was for professional use only and not available to the general public. Optimum Opti-Coat 2.0 was modified slightly from the original professional formula, (The pro version is still available under the Opti-Guard name.) Optimum Opti-Coat 2.0 cures more slowly, which gives you more time to apply the coating correctly. It's like adding an additional layer of clear coat to your vehicle.
When used on a properly prepped finish, Opti-Coat 2.0 will look clear, clean, and smooth. Opti-Coat 2.0 will not wash off and regular washing is the only step needed to maintain the shine.
![](http://www.autogeekonline.net/gallery/data/1068/opti-coat-3.jpg)
![](http://www.autogeekonline.net/gallery/data/1068/opti-coat-2.jpg)
![](http://www.autogeekonline.net/gallery/data/1068/opti-coat-4.jpg)
![](http://www.autogeekonline.net/gallery/data/1068/opti-coat-5.jpg)
Optimum Opti-Coat 2.0 Permanent Paint Coating
