Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
Cleaning Wheel Well
Old Mar 31, 2011 | 11:25 AM
2quik's Avatar
Cleaning Wheel Well
Whats the best cleaner to use for the wheel wells? I was looking at the Meguiars APC.. but they have the different ones, the green solution, d101, and then the red super degreaser.
Any help is much appreciated, thanks
Old Mar 31, 2011 | 01:35 PM
06e320cdi's Avatar
2008 ML320CDI
I use P21S, for me it worked better than Simple Green
Old Apr 1, 2011 | 05:29 AM
TOGWT's Avatar
From: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
Undercarriage Cleaning & Care
Your vehicle’s undercarriage; it’s what you don't see that silently awaits underneath your cars. Removing sprayed brine solution to protect your undercarriage is just as important as detailing the paint. Wheel wells, sub-frame, springs, fender well and all of the other black and gray parts underneath the body need detailing too.
After removing dirt, road grime, and etc with P21S® High Performance Total Auto Wash or Optimum™ Polymer Technologies - Power Clean- use a pressure washer (Kärcher Model K5.93M) neutralise the effects of the alkaline sprayed brine solution on the suspension, wheel wells and the undercarriage (See also Road salt)
Never go underneath a car supported by the supplied jack - always use axle stands if you wish to work underneath the car. Always jack the car up at the manufacturer's recommended jacking points. Ensure the jack is in stable contact with both the jacking point (see owner's manual) and the ground. Always work on level ground.
A spray coating of Chemical Guys - Bare Bones not only adds a durable long lasting shine, it also repels dirt but can also hide dirty spots and discoloration between parts, while enhancing any detail .It is possible to do this detail with the wheels on and just jacking the car up, but the ideal way is with the wheels off.
Metal parts use #0000 steel wool and Optimum Metal Polish and then apply a WOWO polymer sealant (Optimum Opti-Seal or Zaino Z-8 Grand Finale Spray Seal) for any rubber / vinyl parts spray with 1z einszett Tiefenpfleger -Vinyl-Rubber Care and Protectant
{Knowledge Management} - Treating experience as a shared asset. If this article was informative and you learned something new, or have any questions feel free to comment. We would love if you shared this article with your friends on Facebook and Twitter or linked to it from your website or blog- Thanks
Also see my Blog for constantly updated detailing info http://togwt1980.blogspot.com/atom.xml
