Is the dashboard Nappa leather too?
But I'm just wondering if the dashboard and door borders (highlighted in the pic below) are also Nappa leather? I'm just wondering if I should use the same leather cleaner and conditioner on them.
http://imageshack.us/photo/my-images/508/30671400.jpg/
1. Use a aqueous (water- based) foam type product to ensure that the perforations do not become blocked
2. Leather Master™ Protection Cream – (Not for use with N-Nubuck / Alcantara®) an aqueous (water- based) protector that places an invisible, breathable barrier between you and your leather
3. Automotive finished leather upholstery used by 95% of OEM is a multi strata covering over the leather hide; pigmentation (colour) and an abrasion resistant urethane. Finished leather s only requirement is to be kept clean and protected, urethane doesn’t require conditioning
Always keep in mind that you’re dealing with the finished coating on the leather and not with the leather hide itself
So for the Nappa seats, your suggestion is to use Leather Master Protection Cream.
How about the cleaner? Should I use Leather Master Strong or Soft cleaner?
How about for the dashboard and center console? I'm not sure if they're leather or vinyl.
Yes
Q:How about the cleaner? Should I use Leather Master Strong or Soft cleaner?
My best suggestion is to buy the ‘Stron’ version and dilute it, if it doesn’t remove the dirt use it undiluted
Q: How about for the dashboard and center console? I'm not sure if they're leather or vinyl.
Nappa
Identifying characteristics - It is highly absorbent and has a random shade colours and grain pattern.
The water-drop absorbency test- water drops will darken the surface, but it returns to its original colour after drying.
Absorbency rate –Medium
Vinyl
Identifying characteristics - it is also usually smooth and fairly soft to the touch.
The water-drop absorbency test- water drops will ‘bead’ on the surface
Absorbency rate -Low
Leather Upholstery Type Surface Identification - http://togwt1980.blogspot.com/2010_09_01_archive.html
Yes
TOGWT, I ordered the Leather Master Strong Kit as you have suggested. However, I was surprised to see that the label at back of the cleaner bottle clearly stating "DO NOT use on aniline leather..."
Is this really safe to use on my AMG Nappa leather seats? Since according you said it's Nappa Leather (A-Aniline // Non-Coated).
Apply the selected cleaning solution in an inconspicuous area and rub gently with a clean, white micro fibre towel. Do not over wet. Use small amounts of the product, do not rub or use too much pressure. Do not use the product if it adversely changes the material’s colour or texture.
