The Big Bad DeWalt DWP849X is in stock!
The DWP849X has all the standard features of the DWP849 but features a more user friendly design. The DWP849X comes with a three position bale handle that is fully adjustable along with the standard side handle. The casing of the unit features soft grip rubber handle along with a rubber gear case to prevent marring or scratching if contact accidentally occurs with the paint.
DeWalt listened to all the professional detailers and avid enthusiasts when engineering the DWP849X because it now has the ability to start a 600 RPM along with a CFS Controlled Finishing System with soft start to ensure a high quality finish every time. The unit is also several pounds lighter than its predecessor for increased accuracy and comfort during extended periods of polishing.
The DWP849X includes a hook and loop backing plate along with a wool compounding pad. To ensure that no wool fibers get in the air intake, decreasing the life of the machine, the DWP849X features wool ingestion shields.
Features:
• Powerful, 12.0 Amp, all ball-bearing construction for long life and performance for the most demanding applications
• Electronic module maintains specified speed under load delivering better finish results
• Conveniently located variable speed dial lets user set maximum speed from zero to 600/3500 rpm for different materials and applications
• Variable speed trigger allows user to control speed from 0 to dialed maximum setting
• Heat-treated, precision-cut steel gears for smooth operation
• Wool Ingestion Shields eliminates wool ingestion increasing tool life and reducing service costs
• Non Mar Rubber Gear Case Cover reduces surface imperfections and improves gripping surface
Specifications:
Amps 12.0Amps
Max Watts Out 1250W
No Load Speed 0-600 / 0-3,500rpm
Spindle Thread 5/8"-11
Spindle Lock Yes
Tool Length 17.3"
Tool Weight 6.5 lbs
DeWalt DWP849X
