Gel Coat Labs Marine/RV Machine Polishing Kits
Do you have a boat or RV with a dull, faded, oxidized gel coat? Don't let such a thing hinder the appearance of your investment any longer. Gel Coat Labs Machine Polishing Kits include everything you need to restore the finish on your boat or RV.
The Gel Coat Labs FLEX PE14 Total Polishing Kit includes the vaunted Flex PE14-2-150 Rotary Polisher that has been recognized world wide as one of the smoothest running, most refined, user friendly rotary polishers.
The kit includes the necessary Gel Coat Labs compound, polish, cleaner, and sealant needed to effectively restore and protect even the most neglected gel coat finish. The kit also includes the proper wool and foam pads to be used with each product, along with several other accessories including pad cleaner, microfiber towels, and a Foam Pad Conditioning Brush. The included Gel Coat Labs All Marine Surface Sealant will seal, protect, and beautify all gel coat, stainless steel, and aluminum surfaces.
The next kit is the Gel Coat Labs FLEX XC3401 Light Oxidation Kit. With the power of the Flex XC3401 and advanced abrasives of the Gel Coat Labs Fine Cut Polish, this kit has what it takes to remove light oxidation and restore a smooth, glossy finish on your boat or RV. Lake Country CCS Cutting Pads are included along with several other accessories including microfiber towels, Foam Pad Conditioning Brush, and pad cleaner. The included Gel Coat Labs All Marine Surface Sealant will lock in the shine and prevent future oxidation from occurring.
The last thing you want to do is try to remove oxidation by hand. It's time consuming, and not the least bit effective when compared to polishing with a DA Polisher such as the Porter Cable 7424xp. With the Gel Coat Labs Porter Cable Light Oxidation Kit you can tackle the job of removing light oxidation to restore the shine and luster on your beloved boat or RV with the ease of use of the Porter Cable 7424xp. The kit includes everything you need to make your boat or RV look new again and to lock in the shine with the Gel Coat Labs All Marine Surface Sealant.
What if you already have the smooth-as-butter Flex PE14-2-150 or the tough-as-nails DeWalt DWP849X but still need to restore the finish on your boat or RV? Look no further than the Gel Coat Labs Rotary Total Polishing Kit. This kit includes the necessary wool and foam pads along with the Gel Coat Labs compound, polish, and sealant to restore the shine and luster to your boat or RV using a high speed rotary polisher. The kit also includes several microfiber towels and hand applicators for getting in all the tight spots, along with the Foam Pad Conditioning Brush and pad cleaner.
Check out all the new Gel Coat Labs Machine Polishing Kits on the What's New Page!
