Two New CarPro Products! Iron X Paste & Tar X
Iron X and Iron X Soap Gel changed the way we look at paint decontamination. Iron X is an iron remover that opens up the pores in the paint making the removal of ferrous iron particles effortless. Iron X and Iron X Soap Gel enable you to make your paint squeaky clean before applying your favorite wax or sealant.
With the introduction of Iron X Paste, you now have the ability to remove embedded iron particles in more concentrated areas because of the thick viscosity that cleans to the surface, allowing the product to work longer. When it comes time to remove stubborn iron deposits on wheels and paint, Iron X Paste will be your new go-to solution.
Removing tar and adhesive on automotive finishes is never a fun task. You're often faced with products where you aren't sure if they're safe on your delicate clear coat. The product may say clear coat safe, but if it has hundreds of other uses including removing oil stains from the surface of a driveway, are you sure you want to use it on your paint? I didn't think so.
If you're a professional detailer, you're often faced with this issue. Well the solution has arrived with Tar X by CarPro. Tar X is a glow-in-the-dark bug, tar, and adhesive remover that's clear coat safe. Tar X contains no harsh chemical solvents that will harm your delicate clear coat finish. Like several other CarPro products, Tar X changes color to show that it's working. With Tar X by CarPro, you can be sure that the surface you're working on is free of bugs, tar, and adhesive. Give your vehicle the best with Tar X.
Tar X
Iron X Paste
