Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
HD UNO Results
Old Jun 20, 2012 | 05:53 PM
Tom@3dproducts's Avatar
Former Vendor of MBWorld
Jetta
HD UNO Results
Here are some examples of the imperfections I was able to remove using HD UNO. No other finishing polishes in any of these pictures. HD UNO was used to cut, polish and finish, I just changed to the appropriate pads.
You can cut, polish and finish with HD UNO on nearly any paint. Most of the time, the only product you will need to polish. It keeps detailing an enjoyable and simple process. On very finicky flat (non metallic) paint, UNO will not finish perfect with DA (dual action) type machine. In those cases, HD POLISH will do very well. While HD UNO has a long working time, it is not oily and wipes off very easy. Less is more! That is the single, most important thing to remember about the product. Use the amount that you normally use with other products and it will not cut as well. It will polish the paint fine but the cutting ability is greatly reduced, so always remember to use less.
As always, if you have any questions, don't hesitate to ask.
PROTECTED with HD POXY
PROTECTED with HD UNO
