*NEW* Speedy Surface Prep Towel - Clay Bar Replacement!
Former Vendor of MBWorld
2010 S550
You asked for it, and we got it - the Speedy Surface Prep Towel is now available at Autogeek!
If you think that's the best news you've heard all day, wait until you see the Detailer's Speedy Surface Prep Towel Combo for only $5 more than the towel itself!
The Speedy Surface Prep Towel is essentially a microfiber towel with a high-tech polymerized rubber coating applied to one side. This polymerized rubber coating grabs above surface contaminants and pulls them away from the surface, leaving you with contaminant-free paint. As a detailing enthusiast, you should know that shiny paint comes from clean paint!
A traditional detailing clay bar will yield 10-20 uses, depending on how contaminated the surface is. The Speedy Surface Prep towel will provide up to 100 applications, making it far more cost effective in the long run when compared to traditional detailing clay bars. What if you drop the Speedy Surface Prep Towel on the ground? Don’t toss it like you would a clay bar! Simply rinse it off with water and it’s ready for action once again.
Detailer’s Speedy Surface Prep Towel Combo
