Wes_R x GTR (82 pics)
It's been awhile since my last write up here https://mbworld.org/forums/detailing...-126-pics.html but I have been a little busy.
I had spoken to this owner over the span of a year and we had finally set up a date to 2 stage polish this Solid Red GT-R some time in the beginning of August. The car was a garage queen and the swirling was not so bad... actually one of the better condition GT-Rs I had worked on but we wanted to get a 9, 9.5 out of 10 correction so we agreed on a 2 stage polish.
Moving on to the write up here is the first walk around the car.
Already noticed a buffer trail that needed to be corrected
As usual starting with the rims, I cleaned the face and behind with a microfiber wash mitt
Used my brush to clean the calipers
A stiff brush to clean the tire wall
And my EZ Brush to clean the inner barrel
The wheel wells were cleaned also with APC and a curved handle brush
The exhaust was not to bad and was sort of an easy clean up
Moving on to the engine, it was not at all in bad shape but just a little dusty and could use a quick clean up and dressing to make it look new again
Dusty
All clean and dressed up
Artsy Fartsy shot
Stop lying
I pulled out another detail brush and took care of the tight areas like the vents etc
Finally getting onto the wash stage the car was foamed down
While the car was foaming I realized I had forgotten to clean the gas tank
I 2 Bucket Method washed the car with my natural sea sponge
And rinsed off my sponge in the water only bucket after every panel or half a panel
Then dried the car with a plush microfiber towel
Brought the car in to clay
And it was not in bad shape at all
After the claying I measured the paint to see what levels I was working with
I found a section that was repainted and learned that the car had come with a huge scratch from the factory and this section was repainted under warranty which I guess also explains the buffer trail I first noticed
repaint
I masked all the rubber trim
Before
After
Before
After
A quick shot of yours truly polishing
Before
After
Before
After
I alcohol wiped down the car and begin to prepare for the 2nd stage of polishing. The paint was already shining very well but I wanted to push the gloss a little higher so I jeweled the paint with Menzerna Po85RD a white Lake Country pad and my Flex3401.
Here is a the gloss I was achieving with this combination
I gave the paint a 2nd and final alcohol wipe down to clean off the polishing oils then unmasked the car
After unmasking and cleaning off the polishing oils I inspected the paint with my 3M Sun Gun which omits the same spectrum light as the sun.
Perfect
I had to take another shot of the gloss, and this was with no wax on, only polishing
Wax of the day was Swissvax Concorso
Applied
Here are a couple after pics of the exhaust
And I cleaned the windows with my Glass Master Pro.
Unfortunately it had rained but I got a small window to quickly take a few after shots which I don't think turned out that bad and actually it was kind of cool to still see the paint looking very glossy on a cloudy day
The gloss was looking very nice in this pic
Some nice reflections
I liked the reflection in this shot
And to complete the walk around
Finally my last 2 favorite pics
Not wanting to push my luck with the rain I quickly put away the GT-R in the garage.
Hope you enjoyed the write up and seeing the different steps of the detail.
Best regards!
Wes
