Introducing 3D/HD's Strongest Compound>>>
Former Vendor of MBWorld
The dirty one...
I'd like to formally introduce to you High Definition Car Care's lastest creation:
HD CUT
HD CUT is an advanced non-diminishing compounding cream designed to quickly level 1200 grit or finer scratches from fresh or cured paint. Body Shop safe and contains no wax or fillers. Use HD CUT with your choice of Rotary, Dual Action or Forced Rotation correction machines via wool or foam pad. Emulsified with the latest in European NANO-abrasive & lubricating technology that is both sun friendly all while producing ZERO dust with an incredible level of cutting power. Depending on paint type, HD CUT can be followed by HD Polish to produce a flawless, deep & swirl free finish. If excessive marring occurs (which is uncommon), HD UNO may be needed as an intermediate step prior tofinal polishing.
HD CUT is a true paint defect leveler and contains no fillers or masking agents. Specially engineered European NANO-abrasives & lubricating agents make defect correction and surface removal extremely easy. With HD CUT’s new super micro abrasive NANO technology you can achieve the ultimate finish with less work and less mess. HD CUT can be used both indoors and in direct sunlight in most instances.
HD CUT is ideal for all forms of detailing environments including high volume, dealer, high-end enthusiast, body and restoration paint shops. Does not produce any harmful airborne particles that will cause fish eyes in refinish environments. 100% Body Shop safe and contains no wax, silicone or fillers. Can be used on all paint types including fresh or fully cured paint, single stage or get coat. Also great on headlights, fiberglass, RV’s, boats, airplanes and aluminum.
Sizes: 16oz, 32oz & Gallon
Price: To be announced
Directions:
Shake Well BeforeUse. Use a cutting pad of your choice. For best results use HD® Pads. Prior to use, condition pad by misting it with HD® Touch. Apply 6-8 pea sized drops tothe pad for initial priming and work on a 2’ by 2’ area. After each pass, clean pad with compressed air, pad spur or your choice of cleaning tool. Follow up with 3-4 pea sized drops for additional passes cleaning your pad after each pass.
Speed:
*Optimal Rotary Buffer range of 1000-1800 RPM.
*DA Orbital set to 6000 OPMs.
Use moderate and firm pressure, let the machine, cutting pad and HD® CUT tm do all the hard work. Make several slow overlapping passes until desired results are obtained. Mist panel with HD Touch and wipe using a clean dry micro fiber towel. Repeat as necessary. To reach ultimate gloss and defect-free finish, follow-up using HD® POLISH.
![](http://i485.photobucket.com/albums/rr214/PolyProDetail/HD-CUT-LABEL_32.jpg)
![](http://i485.photobucket.com/albums/rr214/PolyProDetail/DSC_0429.jpg)
What's almost as special as HD CUT, it the newly designed spout that will be offered as well.
HD CUT
Directions:
Speed:
![](http://i485.photobucket.com/albums/rr214/PolyProDetail/DSC_0468.jpg)
