Restoring better transparancy of rear plastic window
The three year old SL500 we purchased Dec 1999 seems to have some srot of build up on the inside surface. Where the top when stored has the plastic up against the top liner and storeage compartment liner?
Any comments on I found a convertible top maintenance guide on the web:
Site address:
http://www.automotivedetailing.com/...ibletopcare.htm
A couple of lines extracted to do with plastic windows:
"However, if the window is made of plastic, special care must be taken as this material is easily scratched. I recommend using just a damp, clean chamois (no chemicals!) followed by a smooth (not terry) 100% cotton cloth, ideally flannel. (Note that most window cleaners are not recommended for clear plastic.) If there is heavy grime on the plastic window, use a cleaner specially designated for clear plastic."
"Clear plastic windows that are not so clear anymore can often be polished back nearly to their original transparency. Considering the cost of replacing this kind of window, not to mention the safety issue of driver visibility, the detailer can make a hefty profit on this type of service. There are clear plastic cleaners and polishes that, combined with careful use of a small-head random orbital polisher, can produce amazing results."
I'll just have to find a detailer familiar with these proceedures and suitable products.
Some one on another section of this forum sufgested they have had good luck with "McGuire" products.
Is there any point in checking out marine / boat shops. Yjey have plenty of plastic to maintain.
Comments? Suggestions?
There are three sets of produts people have recommended.
Other insights?
I don't have a convertible, so I haven't tried it for this purpose, but I did use it on the clear instrument lense in our Passat. The car wash guy wiped it down with a dirty rag, scratching the plastic. The polish did remove most of the small scratches, which looked like 'fogging' on the plastic - but I wasn't able to get out the deeper scratches.
You can find the stuff at www. griotsgarage.com.
