Review: BLACKFIRE Total Polish & Seal
Since I was working on a Kona blue Mustang I decided it would be the perfect candidate to try BlackFire total Polish & Seal. I used the BLACKFIRE Total Polish & Seal since it was a polish that would remove the swirl marks and protect the paint. BLACKFIRE Total Polish & Seal will clean the paint of contaminants so that it can create a mirror shine and get the maximum protection out of the sealant. When using this product it did not create that annoying dust like some other products. It will also remove wax build up which is saves you time on removing old wax. BLACKFIRE Total Polish & Seal can be used by hand or machine. Since I could not pull the mustang into the garage I decided to try BLACKFIRE Total Polish & Seal in the sun. When applying BLACKFIRE Total Polish & Seal I used a foam wax applicator I was hesitant about applying it in the sun but it actually did not streak.
After I worked BLACKFIRE Total Polish & Seal into the paint it was time to wipe it off. I used a Supreme 530 Microfiber Towel since it is a thick, soft towel that will not damage the paint. After wiping off the polish I noticed it really made the flakes pop. The polish did remove all the swirls that were in the paint which was surprising since I did it by hand and was not expecting them to all be removed. After using BLACKFIRE Total Polish & Seal I decided it was one of the best all in ones I have used and gave me the best results I have seen yet. If you are looking to save time and end up with amazing results then this is the product to use.
