How To Clean Plastic Convertible Top Windows
After the window was cleaned it was time to apply RaggTopp Convertible Top Plastic Window Protectant. When applying the Protectant I used a Microfiber Applicator Pad this would help me get an even coat on the plastic window. The Microfiber applicator has soft fabric which will prevent you from scratching the plastic window or any other surface. Once the Protectant was applied to the window I removed it using the Microfiber towel that is included in the kit. This Microfiber towel has enough grab to remove the residue without putting scratches into the plastic. RaggTopp Convertible Top Plastic Window Protectant can also be applied to marine, and commercial clear plastics. After applying RaggTopp Convertible Top Plastic Window Protectant you can be assured your Clear Plastic will be protected from harmful UV Rays. When using I was surprised at how easy it was to apply! If you have plastic Windows and want to keep them looking new then this product is a must have.
RaggTopp Convertible Top Plastic Window Cleaner & Protectant Kit
