Cleaning the interior fabric....
Fiscal Neo Con Express
hi guys,
in all of the MB's i've owned i have been amazed at how the interior fabrics spot up so easily. hasn't MB ever heard of
stain resistant fabrics?
anyways...woolite is pretty good but if it is really a bad spot i use a chemical by Castle called "two way solvent". 9 times out 10 it will get the job done. test first in an out of the way area just to be on the safe side. sometimes it works so well that i feel it could remove finger prints right off of your fingers!!!
1 Post
w211 & w124
I use this...
It's also good on the bottom of the door where I always happen to kick it with my shoes when getting out of the car. Works great and hasn't damaged the fabric at all. BTW, I have the same Ash interior as you.
Location: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
~One mans opinion / observation~
I use a woolite/ water 5:1 solution for cleaning fabrics
Once your interior is clean, you should use a conditioning/protection product (303 High Tech Fabric Guard) to ensure protected surface will repel dirt and moisture, and again, keep your vehicle in its like-new condition.
~Hope this helps~
Experience unshared; is knowledge wasted…/
justadumbarchitect * so i question everything*
~Hope this helps~
