question on dent repair
2007 E350 Sport
Just discovered a parking lot "ding" over my rear wheel well, on the rim itself. Anyone know if the paintless dent repair methods would work in that particular location?
'99 C43 AMG
Yes, PDR ( paintless dent removal ) is the way to go. Go reputable shop that has been around for a while. If you are in the Maryland, DC, Northern Va area I can recommend someone.
2007 E350 Sport
C434ME
Doesn't the paintless dent removal depend on the dent being on a flat, almost centered position of a body panel, though? My location is not, the basis of my question.
Thanks.
Thanks.
209/W210 Estate /W211 modded by MBENZNL
Paint Less Dent repair
IF The Dent is in a Double wall IE seam It will be very hard to remove the dent ..Unless You Drill through the first layer of sheet metal to Use the Dent Rod...
Make sure the Tech is a Good One .....
