Hand polished vs Electric buffer
( are they the best ) polishers, are they better than hand rubbed, I have heard people burning paint with buffers is that possible, Love my CLK430 woudn't want to mess my paint up , but would like to get the best shine.
The PC pad is undriven, but the shaft moves through a circular 'orbit' rather than spinning in one place. This results in a much lower pad speed, thus much less heat where the pad meets the paint.
This lower heat is not enough to burn through the paint . . . although it is sometimes also not enough to really polish out heavy blemishes in the paint.
I've been using the Porter Cable orbital for about 7 years now. Unless you are using far too coarse of a polish (like the old rubbing compounds), the only way to damage your paint with a PC is to drop it onto the car.
The results obtained with a PC are truly first class, and are far better than you can achieve by hand.
If you read the sticky notes in the Detailing section, you will have a pretty good basis for using the PC.
Once you get started, you'll be amazed at how much better the car looks, and how much easier it is to obtain that better look.
