Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
AerowerkZ - Authorized Ceramic Pro Dealer
Old Jun 16, 2017 | 03:23 PM
AerowerkZ's Avatar
Former Vendor of MBWorld
CLA250
PAINT COATING
Ceramic Pro is a multi-layerable, clear, liquid nano-ceramic coating.When cured, this technology will transform itself on the surface to a permanent, rigid, flexible glass shield.
Its transparent 3D matrix structure protects the surface from minor scratches, graffiti, dirt, aging, premature oxidation. It offers excellent thermal (2500 F), UV, oxidation, corrosion and chemical resistance. A surface that has been sealed with Ceramic Pro 9H stays clean for a longer period of time due to its smoothness and hydrophobic qualities.
Ceramic Pro is permanent coating and can only be removed if maintained correctly using machine polish hence we often sell it with a life time warranty. The unique formulation of Ceramic pro has enabled it to be multi-layered which means the thickness of the coating can be increased with additional layers allowing a thicker/harder film that will increase protection.
Ceramic Pro product range includes both water based and solvent based products with a 30% – 70% Silica (SIO2) content. The products have gone a number of standardized ASTM and ISO tests backing up the claims mentioned above.
Ceramic Pro was originally designed for the oil industry and space industry but expanded quickly into other industries such as automotive marine and aviation.
CharacteristicsTemperatureThe coating can be applied in temperatures as low as -20 Fahrenheit. Once cured, the coating provides protection from extreme temperatures ranging from -50 to 2,200 Degrees Fahrenheit.
Oxidation & Corrosion ResistantCeramic Pro protects paint and metal from coming into contact with water and oxygen preventing oxidation and corrosion. The ASTM B117 Salt Spray Corrosion Test provides a controlled corrosive environment which has been utilized to produce relative corrosion resistance information for specimens of metals and coated metals exposed in a given test chamber. The chemical tests conducted by SGS and internally are: 5% salt spray for 350 hours with results of no visible damage, as well as 5% salt spray for 5000 hours with no visible damage (internal test).
Chemical ResistanceThe coating has 100% resistance against damaging contaminants and harsh chemicals. Once cured, the only way to remove the coating is through heavy abrasion. The chemicals tested and conducted by SGS include: JIS K5400 Alkali, Acids and Salt. This test method identifies how well the coating resists sodium carbonate, sulfuric acid and sodium chloride despite heavy exposure. Result: 5% Na2CO3 for 24 hours: No visible damage, 5% H2SO4 for 24 hours: No visible damage, and 5% NaCL for 96 hours: No visible damage.
Ceramic Pro 9H is our flagship product in the automotive industry.
9H offers a permanent nanoceramic protective protection against minor scratches, graffiti, dirt, aging, premature oxidation, weathering, road salt, rock chips, bugs, bird droppings and even acid rain. It offers excellent scratch, thermal (1382 degrees), UV, oxidation, corrosion and chemical resistance.
A surface that has been sealed with Ceramic Pro 9H stays clean for a longer period of time due to its smoothness and hydrophobic qualities. Ceramic Pro 9H is permanent and can only be removed using machine polish. The unique formulation of 9H has enabled it to be multi-layered which means the thickness of the coating can be increased with additional layers allowing a thicker/harder film that will increase its scratch resistance.
Ceramic Pro Light is often used as a top coat on 9H. It will enhance the hydrophobicity and will also add more color depth and shine to the surface. Light make 9H look amazing! Light can also be used as a stand-alone coating with the following characteristics:
• Durability up to 24 months
• 114 degrees hydrophobic Effect
• Weather & UV Resistance
• High Gloss Finish
• Advanced Chemical Resistance
• Oxidation & Corrosion Resistant
Ceramic Pro Sport – Maintenance Coating was designed for Ceramic PRO 9H maintenance which is an easy to install solution. You can use ”SPORT” to maintain Ceramic PRO 9H to keep the super hydrophobic effect and also avoid the water spots. The install is easy. Sport can also be used as a stand-alone coating.
Old Jun 16, 2017 | 03:25 PM
AerowerkZ's Avatar
CLA250
INTERIOR COATING
Ceramic Pro Textile reduces the surface energy of textile or suede. When liquids come into contact with the fabric, it forms beads and simply roll off whilst keeping the textile substrate dry.
Ceramic Pro Plastic and Rubber is suitable for both interior and exterior. Coated surfaces with Ceramic Pro Plastic and Rubber will give a hydrophobic effect with wear resistance. The product works for both new and old products.
Ceramic Pro Leather has a super hydrophobic effect. Liquids spilled bead up on surface and can easily be wiped away. The UV protection prevents the leather to age. It makes old leather look new.
Old Jun 16, 2017 | 03:26 PM
AerowerkZ's Avatar
CLA250
WHEELS & CALIPERS COATING
Wheel & Caliper cleaning your rims will never be the same! The surface on the wheel or rim gets so smooth that Brake dust and other containments wont bond. Eventually dirt will stick but will come off extremely easy with the use of water and a towel.
Old Jun 27, 2017 | 09:59 PM
AerowerkZ's Avatar
CLA250
Ceramic Pro Gold Package
  • 4 layers of 9H
  • 1 layer of Light
  • 2 stages of polishing (remove swirl marks and other contaminants)
  • Wheel faces coat
  • Limited lifetime warranty
Ceramic Pro Silver Package
  • 1 layer of 9H
  • 1 layer of Light
  • Wheel faces coat
  • 5-year warranty
Ceramic Pro Bronze Package
  • 1 layer of Light
  • Wheel faces coat
  • 2-year warranty
Ceramic Pro Sport Package
  • 1 layer of Sport
  • Wash & clay bar (no polishing)
  • Outlast sealants by 50%
  • 6-month warranty
Ceramic Pro Interior Coating
  • Dash, center console, seats and door panels
Ceramic Pro Glass Coating
  • All exterior glasses
Ceramic Pro Vinyl/PPF Coating
  • Full car
