caring for microfiber
after the i wash the car is there anything i should do the mits (ring them out, through them in the washer and dryer, etc)?
this relates to the first question, should i wash the mits in the washer and dryer every car wash? and can i wash all microfiber mits together? and im assuming you dont use any products like Tide or anything.
and finally, i read the washing instructions sticky but what exactly is a panel of the car? im not sure, but is one panel front driver door, next panel would be the rear passenger door, full trunk (rear) would be another, roof (another), etc?
it says to use a front - back motion when washing. this motion to me is like sweeping the dirt to the back of the car?
im apologize for my beginner level but thanks in advance guys...
do you just chuck it in with other laundry as well or seperate? I was planning just to throw it in with my jeans and stuff cuz washing them seperate would be kinda waste of water :p
also i dont want to go TO overboard on washing so this is what i plan to do: rinse the car off, use microfiber mits w/ meguiars gold glass shampo, shed the water off, pick up spots with waffle weave and maybe clay the car after? im using p21s for the wheels and mother's for the chrome. and windex i guess for the windows. any suggestions?
Roof and windows, sides, front & back
Hood and tops of fenders
Trunk lid and tops of rear quarter panels
front fender's sides above body moulding
Sides of body (above the moulding)
Front and rear bumpers
then lower sides below moulding
then the rocker panels (area below door openings)
Most important - use a seperate sponge or mitt for the wheels!
these are the dirtiest parts and have abrasive brake dust. The brake dust will cause swirls in the paint otherwise.
Either do wheels first or last, but use another batch of wash water for the wheels and under the rocker panels.
Tip: the lower parts of the car get dirty from driving in the rain / winter weather, the upper parts (roof, windows, top of hood /trunk) won't get as dirty.
The parts of the body closer to the road and wheels get the most dirt.
By working from the top down you won't get road grit in the wash water and put swirls or scratches on the large panels on the top.
Also, I recommend using microfiber towels for the body and using cotton terry towels for the wheels - again use seperate towels for the wheels and tires.
When washing your car, use plenty of water; dip your rinse your sponge often.
Work from the top down.
Use back and forth stokes
Use a separate sponge/mit for doing your wheels, and either separate water, or do them last.
Rinse and dry.
When washing your microfiber towels, do not use a fabric softener. But you can use your normal detergent.
Also, make sure your microfiber towels are 100% natural materials and not polyester, or you may scratch the paint.
Although I'm not a pro, here is what I do:
Rinse and dry.
Microfiber Towel Care:
If the towel becomes too dirty, it will begin to “streak”, it is then time to wash the towel. Pre-soak in a liquid detergent / water and then squeeze out wax/polish with your hands and rinse thoroughly. Hand or machine wash in hot (>150oF) water with liquid detergent (Auto-Fiber’s Micro-Restore) this will remove wax or polish, rinse thoroughly twice, do not use bleach (bleach will shorten the life of your Microfiber cloths.) Do not use fabric softener (most contain silicone that the towel will adsorb and it will weaken the towels static charge thereby reducing their effectiveness) towel will also treat the fabric softener as if it was dirt by trying to store the tiny particles of the softener in the towel fibres. This will clog up the micro fibres and render the towel ineffective. Add a quarter of a cup of distilled white vinegar in place of a softener, the vinegar doesn't coat the fibres but instead works to eliminate detergent residue. Be careful when machine washing or drying in mixed loads (Microfiber cloths will pick up lint from other fabrics.) Air dry or you can dry Microfiber cloths in any dryer on low heat, just be sure that the dryer does not dry at temperatures above 235 degrees F as Microfiber will melt if heated too high. Colours may bleed during first washing. Just recently, a cleaning solution was developed specifically for cleaning Microfiber towels, a product called Micro-Restore Detergent that claims to effectively remove dirt without using the bleaches and softeners commonly found in laundry detergents.
~Hope this helps~
Experience unshared; is knowledge wasted…/
justadumbarchitect *so I question everything*
~One man’s opinion / observations ~
~Hope this helps~
ABSOLUTELY!!!
Don't use too much though.
so what happens if i use fabric softener with the mocrofiber towels??
• To clean the towel simply wash it in your washing machine using warm or hot water. If you use hot water the temperature should not exceed 150 degrees F.
• Always wash your towels separately from other fabrics. They have a tendency to pick up lint and other particles from other fabrics and the next time you use your towels this lint will transfer to the surface being cleaned, only making your job harder.
• ONLY USE LIQUID DETERGENTS, never use dry detergents as many times the granules do not fully dissolve and become trapped in the towel. This can cause scratching of the surface you are cleaning.
• NEVER USE BLEACH OR FABRIC SOFTENERS! You simply don't need them. Bleach will damage any fine fabric and fabric softeners deposit a chemical coating on the fabric that you really don't want to transfer to your car's finish or windows.
• Either air dry the towel on a clean line or in your clothes dryer using low heat. AVOID HIGH HEAT! High dryer temperatures won’t damage the towel but can reduce the towel's life span. Also, don't use those toss in fabric softener towels, all they do is deposit chemicals on the fabric that will transfer off to whatever you are cleaning or polishing with the towel.
• If you wash your towels on a regular basis and don't let them get too dirty they will last much longer. As with any fine fabric dirt particles, grease, and other contaminants can cause the fibers to break down so regular cleaning will go a long way in preserving your towels.
• The more the towel is cleaned the fluffier and softer it will get.
• As you use the DF™ Concours Towel you will notice that sometimes a thread will loosen or pull out here or there. This is normal for terrycloth and you should NEVER PULL AT THE LOOSE THREAD! Pulling the thread can cause the weave to come undone or stitching to unravel. Instead, simply trim the thread with a pair of sharp scissors to about 1/4 of an inch from the surface, don't cut too closely. Think of it as giving your towel a haircut from time to time.
Your using it with a wash concentrate, providing it doesn't pick up dirt (road grime or tar) then rinse and air dry will do fine.
