How to remove brake dust from inside wheel and between wheel nuts?
Very heavy brake dust and using brake dust remover sprays didn't work.. Also is there any way I can clean inside the wheel without taking the wheel off?
Try other tire wheel cleaners
LEt them sit on dust longer but never dry.
Go to griots garage and buy a bunch of different wheel brushes which get in all those nooks and cranies
Ditto on both of the above suggestions.
I ceramic coated my rims and it made them so much easier to clean. Dust basically rinses off. Still need some wiring with the woolies or brushes.
MNBobber (12-01-2022)
![](https://mbworld.org/forums/images/ranks/veteran_air_force.png)
Another option that I use after it was recommended by someone on MBWorld is ArmorAll Outlast Brake Dust Repellent https://www.armorall.com/product/out...ust-repellent/. Just spray it on after the wheels are completely clean and let it dry for an hour or so.. So far it has helped a lot to keep my wheels clean
Ceramic coating would be a more permanent solution. Outlast only lasts for a few washings but it's easy and quick to apply.
