Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
Is it ok to use a pressure washer?
Old Feb 16, 2005 | 03:20 PM
mark4's Avatar
2005 CL55
I have my car washed every 2 weeks and find that if I was able to rinse it off and go, considering i live in a warm climate the car would dry for the most part on its own. I can wash the windows later. In other words I do not have a ton of time to spend washing my car but don't wat to bring it in twice a week. I have no expirence washing my car so any advice would be helpful! If a pressure washer is the answer, which kind should I buy?
Thanks in advance.
Mark
Old Feb 16, 2005 | 04:33 PM
ano0oj's Avatar
09' 335i coupe
You'd have a whole bunch of dry water marks I think. Just go to a local dealer or something, and see what they use. All dealers except the highend companies like Aston Martin, use pressure washers(Mercedes, Lexus, Bmw)
Old Feb 16, 2005 | 05:31 PM
revstriker's Avatar
K Car
My advice would be to stay away from pressure washers. If you're able to wash your car each week, all you need is a good finish (polish/wax), and a decent car wash soap, bucket, and car wash sponge/mitt. It will take you about the same time to wash your car is it would to set up your pressure washer. (It takes me about 5 minutes tops on Saturday)
If you don't want to dry your car, you can either buy a water blade and quickly squeegee most of the water off, or buy a Mr. Clean type attachment for your hose and let it air dry (this will reduce, but not eliminate water marks).
Old Feb 16, 2005 | 05:43 PM
unsung's Avatar
06 M3
If you are using a pressure washer at a public car wash it is worth mentioning most of that water is recycled at the facility.
Old Feb 16, 2005 | 07:47 PM
mark4's Avatar
2005 CL55
Thanks for all the advice. I'll stay away from using a pressure washer and try the hose, bucket, special soap, and maybe dry it off with chamies? Any advice for a good on-line source to buy supplies, and which brands are best?
Mark
Old Feb 17, 2005 | 05:49 PM
unsung's Avatar
06 M3
https://mbworld.org/forums/detailing-automotive-care/97948-best-places-online-buy-products.html
Old Feb 17, 2005 | 09:00 PM
mark4's Avatar
2005 CL55
Thanks!!
Old Feb 24, 2005 | 08:33 PM
market000's Avatar
1999 CL500; 1992 500E:1991 560SEC
Hey Mark:
If you have all the stuff.....soap, bucket,towels, etc......you should be able to wash and dry your car in less than an hour...
I can even do my tires and wheels in that time.
High quality terry towels make drying a snap....dont get the cheapies from some discount place.
Old Feb 24, 2005 | 09:16 PM
mark4's Avatar
2005 CL55
Thanks! I plan on going on line and buying some good supplies. I look forward to it.
Mark
Old Feb 25, 2005 | 07:42 PM
TOGWT's Avatar
From: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
Used with caution and in the hands of a responsible person (read anything you want to into this) like the actual owner of the vehicle they are a relatively fast and safe way to wash a vehicle
Pressure Washer:
Electric powered high-pressure washer's can be used everywhere that a normal mains pressure hose would be used, but you should take a few precautions with there use. Beware of forcing water into areas were it can't drain, and don't hold the nozzle too close to paint surfaces for as well as impact damage an excess of water pressure could damage paint surface, it can also remove stripes and vinyl graphics. Be careful when working with the pressure hose nozzle close to the vehicle paintwork, or while working in confined places like engine compartments as it could recoil and cause impact damage, try to keep a three or four foot distance and use the wand at a 45 degree angle They are an ideal tool for the cleaning of fender wells and undercarriage, and for the removal of road salt from these areas.
JonM
Old Feb 25, 2005 | 09:40 PM
market000's Avatar
I have seen where use of a pressure washer has caused rust or corrosion blisters around mouldings or fittings or hardware where they are attached to the paint. Water or moisture is forced under the paint and it turns to steam and bubbles up the paint.
Old Feb 26, 2005 | 05:51 PM
mark4's Avatar
2005 CL55
Thanks for the advice. I have to order the basic supplies at this point and am taking in all your suggestions.
mark
Old Feb 28, 2005 | 11:08 AM
davis449's Avatar
2016 BMW Z4 sDrive35i M Sport
I use the pressure washers at the regular do-it-yourself car washes, but as a previous poster stated, I stay at least four feet from the car when I do it and aim at an angle. I keep a good wax job on my cars and I've never had a problem with using high pressure hoses.
Old Mar 21, 2005 | 11:04 PM
ccweems's Avatar
Pressure washers - great for getting wax off...
Old detailing trick. You know all that wax that manages to get in all the crevices (or in flat black trim)? Use a high pressure washer to blast it out. Also an air compressor is relly great to blow off all the puddled water in places you can't see. That way when you drive off you don't get all those streaks of water when you drive off.
Old Mar 23, 2005 | 10:15 AM
frankie439's Avatar
I just use a leaf blower to dry the car. No swirls and no water streaks when driving.
Old Apr 5, 2005 | 02:32 AM
BigGar's Avatar
2007 Cooper S (I drive everything)
I've detailed high end cars professionally for 20 years in SoCal and have never had any problems with careful use of pressure washers. Don't get the nozzle too close to anything, and don't stay in one place for a long time trying to blow something like a bug off. Really aviod getting close to areas where the paint may have a chip in it, as you can pop off more paint by getting under it. It's really all just common sense. Rubber and plastic trim can also be damaged by too much pressure applied too closely or for too long. Keep the wand moving people.
On the plus side, your paint will stay nice looking far longer because when you do hit it with the soapy wash mit, you've already removed most of the abrasive dirt that causes so many spiderwebs and small scratches. I also use de-ionized water for all my car washing. This is not practical for most do it yourselfers, but you can purchase a Mr. Clean (no I'm not kidding) car wash system and just use the little de-ionizer for rinsing your car off. If you are plagued with hard water in your area this will make a huge difference for you.
Gar
Old Apr 5, 2005 | 02:36 AM
BigGar's Avatar
I've been doing that for years. Great idea. I usually do a quick and sloppy wipe off with a big fake chamois, a quick drive up and down the driveway to spin the dirty water out of the brake rotors, then I go to town with the leaf blower. Keep in mind I'm using the D-I water so I don't have spotting issues to worry about should some drops dry on the car. Once I'm done with the leaf blower, I wipe out the jambs and then spritz and wipe the exterior with a nice microfiber towel and some quality quick detailer spray. It makes for a nice wash job. Of course, wheels, windows, and interior also get some attention, but I can't type forever.
Gar
Old Apr 13, 2005 | 01:46 AM
Bigdot's Avatar
some
i take my car to a do it your self and then i jump on the 73 south and get 'er up to 115mph, then she is clean...
Old Apr 13, 2005 | 01:51 AM
BigGar's Avatar
The 73 used to be such a fun high speed road. Now you absolutely can not drive it without seeing at least one or two well hidden CHP's cherry pickin' the evil speeders. The road is near empty, and there's plenty of bumper to bumper traffic in other areas that are full of people doing seriously dangerous manuvers, but there they are writing tickets on an empty road. . .
I don't even bother taking it any more.
Gar
Old Apr 13, 2005 | 02:01 AM
Bigdot's Avatar
some
the best time to do a speed run is between 12:30-3 am. that is where i (use to) take it to the limit!!! btw where do you live in socal?
Old Apr 13, 2005 | 11:08 AM
BigGar's Avatar
I live down in Vista. I don't get up to the OC very often at that time of night. No 'Benzes in my stable, I just get to work on them and play with them occasionally too. I have a Chevy Duramax diesel pickup that I drive. It only goes about 101 at the limiter, so speed runs are limited to my 2 Suzuki Hayabusa motorcycles. S-22 Between Borrego and Salton Sea has a few nice spots for 180+ runs. There's also a nice place out east of Julian too.
Gar
