What is Service C?
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Our '06 E320 CDI says Service C is due in 26 days. I can only find Service A or B mentioned at MBUSA. The car is 9 months old and has 5,500 miles. Is Service C unique to the CDI?
Thanks.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Thanks.
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
Service A and B were part of the Mercedes "FLEX" service plan.
Your vehicle is part of the "ASSIST PLUS" service plan. The letters A, B, C, D, and so on do not really have a defined meaning like the FLEX A and B did.
When you bring your car into the dealer to be serviced, they will hook up the mercedes computer system to your car and it will tell them what EXACT servicing your car needs. These individual ITEMS that should be performed will have numbers instead of letters. Each number is a certain task/service item that the vehicle should have taken care of, whether it be replace the dust filter, replace the brake fluid, and perform an oil change OR it could just need an oil change. The only thing to be careful of, since at dealers the service writers are used to FLEX A and B cars is, to make sure to tell them it is an ASSIST PLUS service. Once the technician finds out what items are needed, they can quote you how much it will cost to perform the work.
Hope this is helpful.
