Charging Circuit Nightmare...I am lost
1983 Mercedes 300SD
My 1983 300SD Battle Assault Tank is sick.
Strange thing is, when it will start and charge I get the voltage and break wear warning lights on the dash lit up prior to starting. I am 100% sure that when the lights don't come on with the key nothing is going to happen.
All fuses and relays appear to be in working order.
Where am I going wrong here? I have thinning hair and pulling it out is doing nothing for my looks :-)
I have tried to do as much homework as I can. I have the Charging System diagram from AllData and whatever source a mechanic friend of mine has...Your help would be greatly appreciated.
Thank you,
Joe
83 300SD
- New 65 Amp Alternator
- Continuity is good from the fender well block to the plug on the alternator
- Block on passenger side fender well has battery voltage on 2 reds and the blue wire.
- System will not charge.
Thank you,
Joe
83 300SD
